First post, by someguy
hi
i have a copy off
http://dosbox.sourceforge.net/comp_list.php?s … &search=tornado
ive tried thru 0.65 and 0.63 the latter which has been known to work with this game
i mounted floppy via
mount a a:\ -t floppy
it says mounted as local directory, i dont know if its meant to feedback about mount as type 'floppy' or not as it may be related to my problem
the installer runs but after i press start to begin copying files from to my harddisk (which i have mounted and the game recognizes as usable install dir) it just freezes on 0.63 and does nothing
and on 0.65 the installer tells me "to insert game disk into a: or b:"
both times i mount the same directorys into the same locations
ne help?
Reply 1 of 6, by eL_PuSHeR
Try installing the game using NTVDM first. If installation succeedes, use DOSBox to play.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 6, by someguy
how do i do that?
i tried installing thru command.com
and from cmd/command.com i tried running ntvdm before installing.
tho i am unsure how to use ntvdm of it its something invoked by command.com or what
i also tried using windows compablity mode to install
Reply 3 of 6, by eL_PuSHeR
Don't you know how to open an ms-dos box? I think there is a link already at Accesories > Command Prompt
If not > Execute > cmd.exe
You need to have certain ms-dos knowlege for it, though (like changing drives and invoking programs).
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 6, by MiniMax
Rank Moderator
Moderator
Try Start => Run => cmd.exe
Then cd /d A:\ and install Tornado.
_________________
Reply 5 of 6, by someguy
my questoin was about using "NTVDM"
after http://en.wikipedia.org/wiki/NTVDM i didnt knw if it was just referring to command.com, i found a seperate exeutable file in windows dir so i thought i was unsure wether or not command.com or cmd.exe used it or if i had to manualy run it or something
anyway as i stated i tried installing in both command.com and cmd.exe
i even tried to run it thru wine, tho wine has poor dos support
