Populous 2
First post, by Spork Man2k
I am having trouble with installing POP2 from a cd-rom drive. The game itself is on a Creative CD that contains mulitple games, including Yeager's Air Combat, Shadowcaster Ultima VII, etc.
I type in the following commands upon opening of DOSBox v.65:
Z:\>mount C: "C:\oldgames"
Z:\>mount D: "E:\" -t cdrom -ioctl
Z:\>D:
D:\>cd POP2
D:\POP2>INSTALL D: C:
"You have asked to install Populous 2 from drive D: to drive C:.... Press any other key to continue" Presses ENTER
"There was a problem with the install. Do you have 10,818,180 bytes free space? You can type CHKDSK [drive letter]: to find out how much free space you have. Please read your manual section about installing Populous II or you can contact our customer support service department if you have any problems."
How might I go about fixing this problem?
Reply 3 of 11, by Spork Man2k
The command "-freesize 800" added to the "mount C: "C:\oldgames" command did not work for me. What does the -freesize 800 command do for drive size? Is there any other possible solution to this? (As for the games on the C-D, they are: Hong Kong Mahjong Pro, Seven Cities of Gold, Yeager's Air Combat, Shadowcaster, Populous II, Space Hulk, Ultima VII, The Savage Empire, Ultima Underworld, Wing Commander Academy)
Reply 4 of 11, by MiniMax
Rank Moderator
Moderator
http://dosbox.sourceforge.net/wiki/index.php? … rograms%2FMount
_________________
Reply 6 of 11, by MiniMax
Rank Moderator
Moderator
What kind of file is D:\POP2\INSTALL ?
An BAT-file, or an EXE ? If it is a BAT-file, could you attach it here?
_________________
Reply 7 of 11, by Spork Man2k
It is a .BAT file, and I have attached it. Unfortunately the site does not allow .BAT extensions, so I had to archive it into a .ZIP folder.
    INSTALL.zip
    1.06 KiB
    150 downloads
Reply 8 of 11, by vasyl
Try this: instead of doing "d:, cd \pop2, install d: c:" just run "install d:\pop2\ c:"
If everything else fails you can just copy contents of POP2 directory on the CD to c:\pop2 -- that's all that install is doing anyway.
Reply 9 of 11, by MiniMax
Rank Moderator
Moderator
Here - a fixed version of INSTALL.BAT
    install.zip
    1.06 KiB
    154 downloads
_________________
Reply 10 of 11, by vasyl
Nice job, MiniMax. I could not try it with DOSBox earlier today so I've missed the actual cause of the problem. Just to save everybody else the trouble of comparing two versions, here's diff output:
28c28 < COPY %1.\POPSAVE %2\POP2\POPSAVE>nul --- > COPY %1.\POPSAVE\*.* %2\POP2\POPSAVE>nul 30c30 < COPY %1.\DATA %2\POP2\DATA>n […]
28c28
30c30
< COPY %1.\DATA %2\POP2\DATA>nul
> COPY %1.\DATA\*.* %2\POP2\DATA>nul
32c32
< COPY %1.\SOUND %2\POP2\SOUND>nul
> COPY %1.\SOUND\*.* %2\POP2\SOUND>nul
This is actually quite interesting. Looks like COPY command in DOSBox still needs some work... I wonder if the original installer worked in all versions of DOS.
Reply 11 of 11, by Spork Man2k
I used a combination of vasyl's idea of copying the files from the C-D to the oldgames folder, then applying the fixed INSTALL file. Then installing it from the harddrive. It works perfectly now, thank you all.
