First post, by hajime
Hi my friends. I am new here, and am very happy to find DosBox since
I loved DOS, although I use Linux. I want to thank all the ones who
contribute to DosBox...you guys are really kind. 😉
WELL, my problem comes when I try to load NeoCD, a Neo Geo CD emulator
for DOS, from DosBox. At the beginning it seems to go well, but then, a
problem with the screen settings appear. I remembered having used it on
Windows and that NeoCD ALWAYS executed in fullscreen. However, executing
DosBox in fullscreen doesn't solve the problem.
Any ideas, mates?
P.S: However, DosBox is very useful with many programs.
It's just this program that doesn' go well.
I really beg ur help, mates.
See ya!!
Reply 3 of 4, by hajime
Hi dudes.
Thanks a lot for the answers... However I would appreciate someone told
me if he/she has had the same kind of problem and how it can be fixed (just to learn a little bit) 😀
Yes, I will try to install the latest version of DosBox!!
Fredo, I tried some time ago with that port, but since I am such an idiot
newbie with Linux, when there was an error (don't remember which) I
had no idea of how to react to correct it...
If I have more problems, I'll post again.
See you friends.
Reply 4 of 4, by hajime
Hi mates.
Sorry, but the Linux version DEFINITELY doesn't work..probably cuz there is
only one version, and not some of them depending on the distribution of Linux.
And about DosBox 0.65...it is not yet available for Linux, only the source code
is available, but I am not wise enough to make it work...and it gives problems
when running "./configure". and "make install"...
So, anyone would know how to change the previous thing about the screen
size (in my 1st message)?
Thanks a lot, dudes!
