First post, by RettMikhal
So Aces over Europe was running fine on my laptop. I gave it to my friend and he complained it sounded cartoony when he fired or got shot, and when playing on his laptop I had to to agree. Upon moving Dos box and AoE to my PC, it sounds a lot like his. Little pixie-like sounds when the guns fire. I had to use install.exe to run it, but when given CHOICES for sound settings, I can only select music, not sound or joystick (I don't have one, but before ripped everything out and installed from scratch I COULD see the option to pick one.)
The Music is running on MT-32 and sounds GREAT. But there's no option to change the sound anymore? What happened, do I have a corruption or something?
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
Delete the dosbox config file (or rename it), create a fresh one like
described in the readme. Don't copy around dosbox.confs from/to
other installations.
Reply 3 of 5, by RettMikhal
I tried messing with DOSBOX's soundblasters, none of them worked the way it used to on my laptop (which now ALSO sounds like pixies.) I uninstalled and reinstalled dosbox and it still doesn't sound right. The RESOURCE.CFG file looks like this:
videoDrv = VGA320.DRV
soundDrv = MT32.DRV
joyDrv = NO
mouseDrv = none
memoryDrv = none
modules = 0
latest = 0
toggle3 = 1
toggle4 = 1
toggle5 = 0
toggle6 = 0
toggle7 = 0
minCPU = 386
minDOS = 500
minEMS = 336
directory = \dynamix\aoe
cmd = aoe
So I don't understand why it sounds so horrible.
Reply 4 of 5, by collector
Because of this:
RettMikhal wrote:
soundDrv = MT32.DRV
If you don't have an MT-32 or MUNT with the MT-32 ROMs The sound will be crap. Select ADL.DRV
Reply 5 of 5, by RettMikhal
That did it. Thank you so much for your help, guys.
