First post, by tophilis
am new to dosbox so i know nothing about it. i downloaded crusader recently and i followed these set of instructions...
1. Unpack DOSBox into whatever directory you want.
2. Create some directory somewhere (here I'll use directory "HOME" within DOSBox dir) and remember it.
3. Open dosbox.conf.
4. Changes you'll probably have to make:
[sdl]
fullscreen=true
[cpu]
core=normal (dynamic for Crusader: No Regret)
cycles=30000 (vary between different PCs)
5. Run dosbox.
6. Mount system root FS by typing:
mount c "c:\dosbox\home" -freesize 600
Instead of c:/dosbox/home type your directory. Freesize is amount of free size allocated for your emulated drive in megabytes.
8. Mount CD image by typing:
mount d "c:\downloads\crusader.no_remorse.iso" -t iso
9. Run game installer by typing:
d:\install.exe
10. Follow installer instructions.
11. When done type:
c:\remorse\remorse.exe (or regret.exe in case of Crusader: No Regret)
but when i enter the 6th step i get this message:
Usage Mount Drive-Letter Local-Directory
So a MOUNT c c:\windows mounts windows directory as the c: drive in dosbox
after that am unable to proceed with the other steps. i dont understand any of it. Please help.
about my computer:
CPU: Intel Pentium 4 2.80GHz 2800MHz
Bus Speed: 800MHz
Motherboard: Hewlett-Packard 0984h
System: Hewlett-Packard HP dx6100
BIOS: Hewlett-Packard 786C1 v01.57
Memory: 503MB
Video: Intel(R) 82915G/GV/910GL Express Chipset
Audio: Intel(R) Integrated Audio
loku
Reply 1 of 1, by wd
Rank DOSBox Author
DOSBox Author
Does c:\dosbox\home exist? What error message did you get exactly??
