swiv 3d no cd ?!
First post, by Darkcraft
I want to play swiv 3d and I hav al legal copy of the game. I installed it and started it but it didn't start. I went to dosbox and mounted the cd an my hd started it an i get no cd found!?
Reply 1 of 22, by eL_PuSHeR
Rank Moderator
Moderator
WELCOME TO THE FORUM, Darkcraft.
You probably forgot to mount the CD drive. Write down here all commands you used.
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 22, by Darkcraft
Uuuhm lets see.
HD = D:\
Disk = E:\
I did this:
Cd in the player. Installed Swiv 3d for DOS. Launch DOSbox. Mount my HD http://i191.photobucket.com/albums/z41/Darkaquarium/Knip […]
Cd in the player.
Launch DOSbox.
Mount my HD
Then added my disk
Then i typed these codes :
d:
dir
cd swiv
swiv_dos.exe
Then it will start and shows me SCI (makers of the game) and then suddenly it crashes an says this :
Reply 3 of 22, by MiniMax
Rank Moderator
Moderator
Try this:
Launch DOSbox.
Cd in the player.
Mount my HD
Installed Swiv 3d for DOS from inside DOSBox.
_________________
Reply 15 of 22, by MiniMax
Rank Moderator
Moderator
You need to put the filename in quotes if it contains spaces:
imgmount F "D:\SWIV 3D.cue" -t iso -label "SWIV 3D"
_________________
Reply 17 of 22, by ADDiCT
Maybe the game checks for the audio tracks on startup. An ISO image will not contain any audio tracks. You have to create a BIN/CUE image, and mount the CUE in DOSBox, in order to get CDDA.
