First post, by Parker Lewis
Hello!
I use DosBox0,70. I tried to start the games SCREAMER 2 (german: bleifuss 2) and ALONE IN THE DARK 3. The can be installed from CD in DOSBOX, but when I want to start them, the games tell me taht they cannot find the CD. What shall i do?
I entered these commands:(doxboxconf)
mount c e:\
mount d j:\
c:
e is my drive with the games and j my dvd-rom. i also tried to use the burner (i), but it´s the same problem
The following are things that should be in your help request:
Motherboard
i don´t know
Processor type and speed
1,8 ghz amd athlon
Amount and type of RAM
256 mb
Video board w/ RAM amount and type
geforce 5500 128 mb
Sound board
on board
Operating system
win xp
Game name (and version, if applicable)
screamer 2, alone in the dark 3
Reply 2 of 10, by Parker Lewis
ok AITD3 works now. sry id didn´t read the read me. but screamer 2 stays with a black screen, in low grafics it still says taht there is no cd. here is what i wrote:
# Lines in this section will be run at startup.
mount c e:\
mount d j:\ -t cdrom -ioctl -usecd 0 -label
c:
cd b2
Reply 5 of 10, by MiniMax
Rank Moderator
Moderator
Parker Lewis wrote:
it says:
mscdex installed
drive d is mounted as CDrom j:\
It says that when you enter the command mount -cd (with a minus, a c and a d?)
Parker Lewis wrote:
i don´t get what label i shall enter. where can i check it?
Open "My Computer" and look at your J-drive when the CD is inserted. Does it show the name of the CD? Like SCREAMER2 ?
_________________
Reply 6 of 10, by tannerstevo
I run screamer 2 by mounting the cd as follows;
mount D D:\ -t cdrom -ioctl (my physical cd drive is D).
I have not had to use the -usecd or -label commands.
btw, cd label is SCREAM2.
Reply 9 of 10, by ADDiCT
Forget about using the SVGA mode, your CPU is too slow for that. Set core to "dynamic" (you probably already did that), and play around with the "cycles" setting. There's not much more else you can do. You could swap the DOS4GW executable with DOS/32A, but that will only get you a few percent more performance (if the increase is noticable at all). Best thing you could do in order to play Screamer full-speed and in High-Res is to buy a new system. (; I'm not fond of the recent "hardware-hysteria", but 256MB RAM and a 1.8Ghz CPU is _really_ low-end nowadays.
Reply 10 of 10, by DosFreak
and 1.8ghz was barely close to high-end back in 2002.....
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
