Running M1 tank platoon
First post, by nmlss2006
I've been trying to run M1 tank platoon in DOSBOX 0.71 but unfortunately it freezes hard. By disabling all sound emulation but SB1 I was able to get it to return to DOS when I start tank.com (i.e. I press enter, the machine immediately returns to prompt) but the second time I try to start tank.com the machine freezes. Any ideas?
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
Can somebody verify this?
Reply 2 of 3, by SysGOD
i cant reproduce this problem. game starts up normally with all video modes, sound settings and joystick enabled/disabled. even if the files are write-protected...
i've also tryed different core/cycle and audio settings in dosbox.conf without a single crash or freeze.
maybe you have a bad or broken copy? try reinstalling it or get another version.
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
Could also be cycle-dependent then, so the default 3000 cycles or lower
might be a good starting value.
