First post, by one_red_eye
Can somebody tell me how to get past this screen? I don't have a floppy drive. I'm using Dosbox 0.70 on dual core athlon 64 w/ 2G ram in gentoo linux.
http://img530.imageshack.us/my.php?image=snapshot1tb7.png
    9.61 KiB
Reply 1 of 4, by dougdahl
If that directory contains the files from the floppy, you could try mounting it
with the "-t floppy" option. That should make dosbox think that it's a floppy.
You might have to install it, so it might not hurt to have another directory set as the c drive.
On the other hand it might be some form of copy protection. If so that could be a problem.
Reply 2 of 4, by one_red_eye
I've tried mounting with "-t floppy" which didn't work. I think it is some form of copy protection. But I've found lots of forums where people say it works fine. Even a video on youtube.
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
See if you can find an 0.72 version.
_________________
