First post, by DosFreak
http://www.microsoft.com/downloads/details.as … splaylang=en&tm
The Microsoft Application Compatibility Toolkit (ACT) 5.0 helps customers understand their application compatibility situation b […]
The Microsoft Application Compatibility Toolkit (ACT) 5.0 helps customers understand their application compatibility situation by identifying which applications are compatible with the Microsoft® Windows Vista® operating system and which require further testing. ACT helps customers lower their costs for application compatibility testing, prioritize their applications, and deploy Windows Vista more quickly.
You can use the ACT features to:
* Verify an application's compatibility with a new version of the Windows operating system, or a Windows Update, including determining your risk assessment.
* Become involved in the ACT Community, including sharing your risk assessment with other ACT users.
* Test your Web applications and Web sites for compatibility with new releases and security updates to the Windows® Internet Explorer® Internet browser.
System Requirements […]
System Requirements
* Supported Operating Systems: Windows 2000 Service Pack 4; Windows Server 2003 Service Pack 1; Windows Vista; Windows XP Service Pack 2
* Supported Database Components: Microsoft® SQL Server 2000, Microsoft® SQL Server 2005, Microsoft® SQL Server 2005 Express Edition
* Miscellaneous Software Requirements: Microsoft® .NET Framework, version 2.0
Important: The Application Compatibility Manager, the Internet Explorer Compatibility Test Tool, and the Compatibility Administrator are not supported on Windows 2000; however, you can run data collection packages and the Setup Analysis Tool on computers running Windows 2000 with Service Pack 4 (SP4) and Update Rollup 1
Make your games work offline
Reply 1 of 2, by Zup
Where can I get older releases of ACT? I need one of those for a Windows 2000 laptop, but in 5.0 Application Compatibility Manager won't work.
I'm selling some stuff!
Reply 2 of 2, by DosFreak
You can modify the ACT MSI with ORCA and remove the requirement so that you can install it on Windows 2000.
