Reply 38000 of 53101, by bjwil1991
GigAHerZ wrote on 2021-02-09, 21:15:
Got some stuff from local auctions.
Then a very curious 386 motherboard with cache and 72pin memory! 😮 15€
Now that's a motherboard. If you need assistance with the board, let us know. Currently fixing my Jetway/J-Mark OPTI-495SX 3/486WB board that suffered corrosion and trace damages.
Reply 38001 of 53101, by Aublak
mtgmackid wrote on 2021-02-09, 15:11:
Had a great few days at ewaste, paid more for the 486DX2 ($10) than the cards ($5 per) ;) […]
Had a great few days at ewaste, paid more for the 486DX2 ($10) than the cards ($5 per) 😉
AT tower (Socket 3 board) is missing the cpu and ram but has everything else, including a CT2230, Cirrus VESA and the Creative interface drive. Freetech 486f39x board inside (will take pictures of it soon)
Isn't ewaste great? 😀
Reply 38002 of 53101, by GigAHerZ
bjwil1991 wrote on 2021-02-10, 03:27:
It's currently soaked with white vinegar. Keyboard controller socket is missing some pins already...
All removable chips came out fine. (were soaked in vinegar overnight and cleaned them this morning)
We'll see. Probably need to replace some sockets, maybe some ISA slots and don't know yet about traces on board.
Reply 38003 of 53101, by appiah4
I bought an ATI FireGL V7100 PCIe as a backup for the X850PRO PCIe I currently have in my LGA775. In theory it should be faster but I am too lazy to replace it for now.
Reply 38004 of 53101, by Intel486dx33
quote=GigAHerZ post […]
quote=GigAHerZ post
Quick pull them out of the vinegar bath. I soaked a motherboard in vinegar once and it ate up the capacitors and diodes.
its okay for a quick cleaning and rinse but not good to soak for hours.
Reply 38005 of 53101, by GigAHerZ
@Intel486dx33, if that's the case, i can always replace the caps and diodes. 😉
Reply 38006 of 53101, by CMB75
Acquired an AT midi tower case for my late 486 DX4 build. It does need some cleanup, fixing and retrobrighting but I like it’s calm and clean appearance.
This will be my first AT system which will make use of those fabulous ATX2AT adapters I got from xsecret.
142.24 KiB
Reply 38007 of 53101, by gex85
CMB75 wrote on 2021-02-10, 11:32:
Nice, I have this very model in my collection, too. It was originally equipped with a Pentium MMX 166 MHz on an ASUS TXP4 motherboard, the latter still being in there. I have swapped the CPU for a K5, mainly because I didn't want another Pentium MMX machine 😉
The build quality of this case is not exactly great but not as bad as other cases of the era...
My retro computers
Reply 38008 of 53101, by dionb
[...] And a basis for my "higher-end" pentium 2 class machine. 15€ A ChainTech 6ESA2 motherboard, which has ISA, PCI and AGP sl […]
A ChainTech 6ESA2 motherboard, which has ISA, PCI and AGP slots and has integrated ESS Solo-1 sound card.
I didn't know it before i got it, but it also had one of the most desirable Slot1 celeron - Celeron 300A. Definitely will try to overclock it.
Don't get your hopes up, that board has an i440EX chipset, which - like the i440LX it's based on - theoretically only runs at 66MHz and in practice will rarely clock above 83MHz FSB (and that's a bad speed for PCI...)
My CPUs arrived today:
256.02 KiB
2x i486DX2-66
Pentium 90 (no FDIV bug, unfortunately)
Pentium 166
Pentium MMX 200 CPGA
2x Pentium MMX 200 OPGA
Cyrix 6x86L-PR200+GP 2x75MHz
Celeron Mendocino 466
Celeron Mendocino 500
P3-650E
Celeron Coppermine 1000
P3-1000EB Coppermine (but FC-PGA2 w heatspreader)
2x Duron Spitfire 750
AthlonXP Palomino 2000+
AthlonXP Tbred B 2400+
AthlonXP Barton 2600+
Sempron Palermo 2800+
Athlon64 ClawHammer 3000+
Athlon64 Newcastle 3200+
Athlon64 Newcastle 3400+
Celeron Willamette 1.8
Celeron D Prescott 2.53
P4 Willamette 1.8
P4 Northwood 2.0
P4 Northwood 2.26
P4 Northwood 2.53
P4 Prescott 2.8
P4 Prescott 3.0
Pentium D Smithfield 805
Pentium 4 Mobile Northwood 2.0
Some of the P4 and Athlon64 pins are pretty badly mashed, but the rest is in good shape, if sometimes covered in excessive thermal compound (the pic was after an initial clean, but particularly the SoA CPUs are still messy as hell).
And the 'mystery' So370 CPU? It was the P3-650E. Plain old Coppermine, but with some translucent plastic shim around the legs. Doesn't look Intel-original, but it's pretty securely stuck there. Not seen this before. Anyone familiar with these?
101.94 KiB
Anyway, all I really needed was a SoA test-CPU. I Think at least one of those should have survived (not too sure about the Durons and the Tbred, they have chipped die coreners, but the Palomino and Barton look perfect). Nothing utterly compelling in the rest, but good solid spares the lot of them (if they work). Maybe one day I'll make a Pentium D system if I really have nothing better to do 😉
Reply 38009 of 53101, by mpe
Bought some new variants of Diamond Stealth Trio PCI cards. Now I am not sure which are new and which I already had 😀
Blog|NexGen 586|S4
Reply 38010 of 53101, by winuser_pl
Very nice collection! Tell me how much did you paid?
dionb wrote on 2021-02-10, 13:23:
Don't get your hopes up, that board has an i440EX chipset, which - like the i440LX it's based on - theoretically only runs at 6 […]
2x i486DX2-66
Pentium 166
P3-650E
P4 Willamette 1.8
P4 Northwood 2.0
P4 Northwood 2.26
P4 Northwood 2.53
P4 Prescott 2.8
P4 Prescott 3.0
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 38013 of 53101, by Artex
Bancho wrote on 2021-02-10, 21:10:
Finally managed to add a SC-55 to the midi tower. Tested it out and it works great, then instantly opened it up and removed the […]
Finally managed to add a SC-55 to the midi tower. Tested it out and it works great, then instantly opened it up and removed the battery. Battery was a bit crusty but hadn't leaked anywhere.
How do you like that mixer? I was looking for one with 1/8 in. / 3.5mm inputs like that one.
Reply 38014 of 53101, by Deczor
I'd been looking for bits to make a P133 rig for a while. Got a nice little tower that needs a retrobrite, a PSU that needs a re-cap, a little memory, etc. But the two socket7 boards I have are dead. One won't detect ram, the other has no POST at all. I was going to pay through the nose for a decent working socket7 board, but then I found this in the skip bin at work:
Don't see many Digital machines on here. This one is pretty exceptional. It's lived in a train workshop it's whole life. It was the machine for controlling the tracks and stuff for shifting engines in and out. It was full of train brake dust and crud. Needed to fill it with soap and get the garden hose into it to clean it off, that dust was so sticky. On the bright side it did have some really cool (win95) train and track control and monitoring software on it.
The only thing missing was the CPU, which someone decided they wanted, and left everything else. Cute wee CAS module, 64mb RAM, 1GB hard drive (which tests perfect too). Dropped my 133 CPU in there and it booted right up.
Cleaned up pretty well.
Decided to give it a wee ESS 1868 for sound:
New battery:
Post-wash:
If anyone can tell my why the hell Cannon Fodder keeps on crashing on any machine I install it on, I'd be so happy! For some reason you can't quit the version I have either. You have to turn the computer off.
CF card upgrade, since I want to keep the original HDD with it's original factory software.
Reply 38015 of 53101, by Ozzuneoj
That's a neat system, with a cool backstory! Nice job cleaning it up. 😀
It needs a train whistle for a startup sound. 😁
Reply 38017 of 53101, by Ozzuneoj
Arctic wrote on 2021-02-11, 07:09:
I dont know where else to post this, I am not gonna bid on this, what do you guys think?
https://www.ebay.com/itm/Sony-GDM-FW900-CRT-M … or/164685875289
Wow! New in box... that's a pretty rare item in that condition. Some nutty person will probably buy it.
Having had (and sold) a used one, and made... a lot... I totally don't blame the person for listing it high. People read about it or see it in youtube videos and they simply must have it. Whatever... it pays the bills and funds future projects. 🤣
Honestly, it's a nice display, but the price is mostly hype. Remember, it's nowhere near the newest CRT made, with many (Most? All?) being made before 2001. Later CRTs often have better refresh rates and specs, and the 16:10 ratio of the FW900 is much less useful for retro gaming... plus, when buying used, newer models may have far less usage, since LCDs became much more popular in the mid 2000s and people were replacing CRTs just to save space. Mitsubishi and NEC displays from 2003-2005 have great specs and don't reach the insanely high prices of the FW900. Some of the best will do a maximum of 2048x1536@86Hz, 1600x1200@109Hz, 1024x768@160Hz, etc. At lower refresh rates they are super crisp if they've been taken care of.
Reply 38018 of 53101, by Intel486dx33
I had dual sony 20” displays back in the day but I always wanted the Wide hi-def displays.
The FW900’s use to sell for about $250 on eBay back then.
I never got around to purchasing them because the CRT’s became replaced by LCD’s
We had some Sun Microsystems dual LCD workstations at work.
Post photos of your favorite 1990’s computer.
Reply 38019 of 53101, by mpe
Bought two interesting (not the usual Cirrus Logic) VL-Bus cards. They've never been used apparently. Need to get memory upgrade for the Tseng so that it can benefit from bank interleaving.
Blog|NexGen 586|S4
