Reply 40360 of 53152, by misi77
Thanks, Bro!! Yes, its almost same!
I turn on it, the post screen said its an "UNIC PC S30". Pull out the Rom Bios, and make a copy soon.
Unfortunately, its drop a keyboard error, I couldn't load a system with it.
Do you have any documentation for it? I think the dip switches are not standard XT clone compatible. Supersoft Rom can't read the XT DIP positions correctly.
Many Thanks!!!
Predator99 wrote on 2021-09-02, 18:37:
misi77 wrote on 2021-09-02, 14:13:
Hello, does anyone recognize this MoBo? Its a XT clone with M1101 integrated circuit, integrated serial/paralell ports, and flop […]
Hello,
Its a XT clone with M1101 integrated circuit, integrated serial/paralell ports, and floppy interface, and onboard Varta battery.
I can't find information over the WEB.
Made by VIP.
Thanks!
Have almost the same and mine has a model number
Re: XT BIOS image collection
Reply 40362 of 53152, by cyclone3d
Found this Voyetra V-4000 for sale in a lot of random other cards:
661.33 KiB
Edit: Anybody else seen this type of error on vogons? It happened when I submitted this post:
23.08 KiB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 40363 of 53152, by devius
cyclone3d wrote on 2021-09-02, 19:23:
Yep, I've ran into it once or twice. It my case it seemed to happen when two people try to post at the same time.
Reply 40364 of 53152, by misi77
Ofcourse yes, try with a BTC-5060XT keyboard.
I tried some combinations with SW1, it is almost same as standard XT clone .
I think floppy drive type set by SW2, but i cant find floppy ROM extension onboard, so this MoBo support only 360K/720K drives.
The function of SW2 is still unknown to me.
As i see, CN1 and CN3 are serial port header, CN2 paralell port header, and C4 is gameport.
The keyboard error is a concern, but I will find a solution. (keylock can be opened with a shortcut on KYLO header)
A dump of the ROM BIOS attached.
Thanks!
Predator99 wrote on 2021-09-02, 19:06:
No, I dont have documentation...try all DIPs and look what changes.
Stupid question...your keyboard is a XT one?
http://www.win3x.org/uh19/motherboards/6839
    UNICPCS30.rar
    6.58 KiB
    42 downloads
Reply 40365 of 53152, by BitWrangler
Man you guys are right about prices getting insane for anything Voodoo, I could only afford half of one, paid FIVE times as much as for my last PCIe card (That'll get everyone looking back in the thread 🤣 )
Then there's some kind of crystal media PCI sound card thing... I was hoping it was better, but suspected from the layout it might be an ESS or CM chip under there. Popped my Turtle Beach cherry anyway 🤣
    561.56 KiB
    Guillemot Maxi Gamer Phoenix and Turtle Beach Riviera PCI
Reply 40366 of 53152, by EvieSigma
Hey, I think I have that same Voodoo Banshee card! Though mine seems to have a different screen printed logo, even though they say the same thing.
Reply 40367 of 53152, by BitWrangler
Cool, must be what they call the new logo. Pondering what to run mine in, well it will be a while, but want to have it put in a mental pigeonhole. Think I can dig up a Biostar M5VIA, maybe chuck a K6-233 in it. Or it might end up in a slot 1 PII build.
Reply 40368 of 53152, by sirotkaslo
cyclone3d wrote on 2021-09-02, 14:56:
sirotkaslo wrote on 2021-09-02, 10:01:
I know it's not the correct thread for this, but couldn't find one. How much should I offer for a 486 with the cx486dx4-s@100mhz?
That depends entirely on the rest of the hardware.. mostly the video and sound card if any.
Its got the FIC 486-VIP-IO2 motherboard, can't recognise anything else from this picture he sent me, he's also asking 75€ for it now.
Reply 40369 of 53152, by dataino.it
Hello,
Made by VIP.
Thanks!
can be this http://www.win3x.org/uh19/motherboards/6839
Reply 40370 of 53152, by BitWrangler
sirotkaslo wrote on 2021-09-03, 06:00:
To me it's looking like a Maxtor HDD in the 540-8GB range and a 1 or 2MB PCI SVGA card. Heatsink looks like something that would go on DX4 class. 75€ is probably about half of the minimum it would fetch on eBay these days in auction or a third what it would be on a buy it now listing. Probably worth it for the case and a motherboard you can run "anything" 486 on. If it checks some boxes for you, go for it.
Reply 40371 of 53152, by Nexxen
Bought a 386/486 motherboard, GMB-786UN.
Sports a soldered PQFP AMD 386 40 mhz but has a 486 DX2-66 installed (5V). Crystal is hence 33mhz, thus rendering unusable the 386 (would need an 80mhz crystal).
The battery leaked and damaged some traces, I'll have to test the board and most probably troubleshoot and repair the traces.
Will post pics and manual.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 40372 of 53152, by BitWrangler
The way you said that, it appears you are unaware that the 386 would be perfectly happy running at 33 instead, but I guess you mean you can't use it to it's full 40Mhz potential.
Reply 40373 of 53152, by bjwil1991
Bought a blue glass Q5 screen cover for my DMG-01 Flo from Progressive build, drop-in TFT with the alignment brackets and glass cover for my other GameBoy Color, GB/GBC/GBA adapter for my laptop so I can back up my saves and ROMS on the fly, and 3 GBC capacitor kits as a preventative maintenance.
Well, new hardware for my older consoles.
Reply 40374 of 53152, by TehGuy
Found a Rev 2.0 GA-6BXC posted just today for under half what I paid for the Rev 1.7 (granted, it did come with a Celeron and RAM). It does have a broken slot rail thingie (the black plastic holders on the side of the slot), the BIOS DIP IC is missing, and it looks like they popped the 440BX chipset's cooler off to fit the massive 2-fan monster they have on the included PII, but guess who now has spare parts for those, eh? Plus now I've got a known working Celeron and PII. And the backplate for the board
...maybe my parts hoard is getting too large; is it possible to turn into some retro dragon? Maybe it'll help when I offload some of this onto the local-ish retro communities I'm a part of on Facebook
Downside: my fun time wont happen possibly until next weekend when it arrives at the latest 🙁
Upside: no more spending money 😀 (for now)
427.81 KiB
The transplantee
Win98+DOS: C3 Ezra-T 1.0AGHz / P3-S 1.26GHz, 128MB RAM, AWE64 + Orpheus + Audigy 2 ZS, Ti 4200, 128GB SD card
Win XP SP3: C2Q 9650, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
Reply 40376 of 53152, by EvieSigma
BitWrangler wrote on 2021-09-03, 02:55:
Mine is in the system I pulled it out of (Asus P5A, K6-2 500MHz, 256MB of RAM). Works quite well!
Reply 40377 of 53152, by BitWrangler
EvieSigma wrote on 2021-09-04, 02:19:
Nice, yeah I could do that too, got the AT P5A. I was thinking of blessing that with one of the Voodoo 3s (Should they ever freaking turn up) but I could banshee it first and see.
Reply 40378 of 53152, by BitWrangler
TehGuy wrote on 2021-09-04, 00:12:
I wouldn't recommend it, bit knobbly to sleep on.... though having said that, there is a non-zero amount of PC spares under my bed. For a number of years that included an XT clone board and some cards from it, which I removed and put "somewhere safe" so of course I have no clue at all where it is now.
Edit: 2023 update, they actually turned up somewhere hecking unsafe, see posts from Oct '23 in dumpster find thread.
Reply 40379 of 53152, by Pierre32
Picked these two up together, as the only bidder. I wanted the ARK, and the Cirrus was just extra weight in the package. When they arrived I took the opportunity to benchmark my small collection of PCI cards, and to my surprise the Cirrus is nipping right at the ARK's heels. So that's the two quickest 2D cards I have now (according to the venerable PierreMark). Pretty happy for a fiver!
476.96 KiB
46.41 KiB
