Reply 54840 of 58512, by BitWrangler
- l33t++
PcBytes wrote on 2024-10-22, 16:57:Funny enough, the caps in the VRM are actually original to the board - the joints look factory, no residue around them or anythi […]
BitWrangler wrote on 2024-10-22, 16:29:PcBytes wrote on 2024-10-22, 13:22:Look who showed up from Poland 😀
If you haven't heard me say so before, those go really fast with OPPainter BIOS settings if you can dig them out of the web... or the archive if that's back up.
Looks like maybe main caps have been replaced, but those green ones around the RAM might have to come out.
Funny enough, the caps in the VRM are actually original to the board - the joints look factory, no residue around them or anything.
The Teapos will defo' come all out, black or green. I'm planning a polymer recap if I can get hold of 820uF polys, as well as some suitable replacements for the 470s.
Got to check if the archive is back up, then off to diggin' OPPainter's KG7 BIOS settings.
EDIT: Couldn't find the PCPer thread... however I found this:
https://forums.ocworkbench.com/showthread.php?p=88918Apparently they're obtained from both OPPainter and DDTUNG.
Yup that will do the business. Might be all you need. There was a little bonus information for WPCRedit tweaks originally also. But those really get you flying, make KT266 look lame, go past 266A, embarrass most of the KT333 implementations (there seem to be a lot of sucky ones) and say to nforce, knock knock, I'm in the neighbourhood you win9x incompatible poser.
