Reply 57200 of 59423, by chrismes
- Newbie
myne wrote on 2025-07-16, 17:05:PcBytes wrote on 2025-07-16, 12:58:Thanks! I got it to work with a mild 365*C reflow on the southbridge. No preheating as I don't have one nor the means to get/DIY one.
Nice! All good now?
Pre heating is recommended because spot heat can warp a board pretty severely. I tried to replace an lga socket once without one and the board bowed easily 3cm
I use an old desk lamp with a cheap infrared bulb for pre heating. I check the temps with a laser thermometer and move the lamp around a bit. Works great for the few times I need it.
