Reply 59860 of 60068, by Nexxen
Intel486dx33 wrote on 2026-10-09, 02:15:
Don’t copy that floppy.
Back when 5.25 were common my father bought 3M many times.
I loved the sliding design.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 59861 of 60068, by momaka
Trashbytes wrote on 2026-10-08, 13:46:
The two dead ones are dead Jim, they won’t post on any boards I have for testing, Z97, Z68, x58 and my 754 board all refuse to post with them.
I didnt bake them, not sure that would help though, open to trying weird stuff with them since they are dead.
If you have a PCI-E 1x miner riser card/board, try these video cards with that.
Sometimes on these Radeon cards when the GPU starts going bad (usually due to too high of running temperatures under load), it might loose a lane or two on the PCI-E bus. When that happens, so long as the 1x lanes are not affected, those miner riser cards will allow the video card to boot and show video. If your HD7770's work on a miner card but not otherwise on the board, then that's probably the issue - i.e. bad PCI-E bus lanes in the GPU chip. (Of course, this could also be due to bad or knocked out ceramic coupling caps on the PCI-E bus on the video card... so check those too.)
If that doesn't work, then it's baking time for the video card.
No need to actually really bake the video card, though - at least not in your oven, as that's almost as likely to damage it or ruin something else on the PCB (including melt the output connectors.) I prefer either cooking (literally) on a stovetop or using a heat gun. The former works quite well on gas burners if you raise the video card at least 5 cm above the flame. Was my GO-TO "PCB bottom heater" for years.
Trashbytes wrote on 2026-10-08, 13:19:
Also grabbed a couple of nice Radeon HD5770 cards too that came as a X-Fire pair and a HD7770 Ghz card, none of them have been tested yet but Terrascale 2 cards are pretty hard to kill like the Cockroaches they were born from.
I have seen plenty of dead HD5770's. They pretty much all come with undersized coolers for the GPU's TDP, regardless if they are OEM design or 3rd party design. Had they come with something like the HD4870's coolers (which is far from ideal for the HD4870's 150W TDP), they'd probably last for decades.
The HD5750 is in a similar boat. It's got the same chip as the HD5770, but slightly underclocked and with less shaders, so it only uses ~85W TDP instead of 100 Watts like the HD5770. But it too often comes with a basterdized cooler.
Nunoalex wrote on 2026-10-01, 18:59:
Look at this gorgeous beauty that came my way 😀
Soltek SL-86SPE-L
It has a PCI slot bent I hope I can put it back in place
Nice!
After reading your post last week, I also found me a Soltek board on my local flea market.
Mine's a Socket 462, though.
No bent PCI slots, but it does have bulging caps just like yours. Came with a AXP2000 CPU too.
No idea if it works or not. But for 8 Euro, it was worth it, even if will just be wall piece (if it doesn't end up working.)
Seems I had good luck that day with purple-colored PCBs, because I also got an ECS socket A board of some sort. Forgot the model number, but it's in the "waiting for repair" box ATM - has a burned RS232 chip behind the parallel port. Let's hope that's the only thing wrong with it. It was 1 Euro after all, though, so I can't complain.
Reply 59863 of 60068, by Nexxen
Intel486dx33 wrote on 2026-10-10, 00:10:
Nexxen wrote on 2026-10-09, 22:51:
3m is the best and Sony is very reliable too.
I have a lot of memorex too, nashua, some sony. What was on the shelf at the middle price IMO.
My father bought 3M because a colleague told him that they were reliable. Saving work stuff.
At some point he made a huge backup on a HDD that later failed. 5.25" disks were still there, working 100%.
All stuff that he didn't need anymore (work related) and didn't make a difference at that point.
A big lot of 360kb he got from another colleague, when he first bought the pc he used for a while, died pretty fast. In '88-89 they were gone, thrown away to be replaced by 1.2mb.
Tainted gift, I believe they probably were Apple disks formatted for pc.
In fact I have a lot of wrong memories, I mix things up and my father doesn't remember too well as it was stuff coming and going.
My mom, being the accounting expert, remembers much more 🤣
All the little things that you do but hold no real significance, like buying groceries. Who remembers what was bought and why 30 years later??
I hope some guy will do a thorough research on media durability, some PhD student.
Reply 59864 of 60068, by BitWrangler
Nexxen wrote on 2026-10-10, 10:22:
I have a lot of memorex too, nashua, some sony. What was on the shelf at the middle price IMO. My father bought 3M because a col […]
There is some specific Memorex I would advise to avoid. Late 1.44Mb 3.5" in translucent colours. They should be among the youngest 3.5" in my house, but every one of them seems to have gone bad/unreliable for reading data off. In contrast, some black Memorex, IIRC bought within a few months of the translucent ones have been fine. Flip the shutter back and hold them to the light and you can see through the disk material easier on the translucent ones. I am curious as to whether the small amount of light exposure afforded by the translucency of the shell accelerated their demise, or whether it was just the coating was done cheap and thin anyway.
Reply 59865 of 60068, by Trashbytes
BitWrangler wrote on 2026-10-10, 12:25:
100% the cheap nasty coating.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 59866 of 60068, by G-X
Picked up some cool stuff for free last week (workplace suddenly came up with these from some "attic" and was tossing them in the van to take to the recycling ... managed to persuade them to let me take them. Obviously since i showed interest they somehow became aware "it must be worth something". Then the boss was having second thoughts and i told them to junk them anyway then. Then the next day i asked what the deal is and he told them ok you can have them.
The attachment oldpcs.jpg is no longer available
Was really hoping the PVM still worked (mind you this thing was downright black with something like soot ... looks like brake dust on a car wheel. The case cleaned up beautifully but man .. initial pass with cleaner and rags only did half of the work... used a magic sponge (carefully) and it became 2 shades brighter ... unbelievable difference (will show pics later on). Its a PVM 2010QM (unfortunately a low tier model with basically a consumer grade tube but in a professional chassis)
Well it works .. somewhat. The Red,green and blue are misaligned ... apparently this is called convergence (many interesting video's on YT) and it's possible to correct this.
(yes i'm aware of the high voltage and the need to discharge the tube before doing any major work)
I need to mod an old console somehow to bring up the CRT test suite for making adjustments.
The attachment trinitron.jpg is no longer available
And also bought this pair for €50 today. I knew the one without the usb tray in the front was a Chieftec Dragon but i thought the other one was an Antec clone from back in the day (120mm fan instead of 2x80mm at the back and then the USB tray in the front). Having them at home made me realise they really look identical and somehow the one with the USB is a later model? I also don't know which sidepanel belongs to which case ... i really like the look of the one without the fan grills in them but i believe this one belongs on the "OG" dragon. I still have my Chieftec Dragon bigtower and that one also has (one) fan grill cutout and the 80mm fans.
Both of them came with S775 era hardware but bottom of the barrel stuff ... but can't complain for the price tbh. I'm hoping to keep one and sell the other with the bunch of hardware and recoup my money and end up with one case for free ... a little brother next to my bigtower dragon if you will. 😉
The attachment chieftecs.jpg is no longer available
The attachment chieftecs2.jpg is no longer available
The attachment chieftecs3.jpg is no longer available
Though i am very tempted to swap the back of the case from the newer model to the older one just to have the 120mm fan instead of the 2x80mm with the ugly purple brackets ... but then again it won't be "Original" anymore.
I can just drill out the rivets and swap them over. Gonna have to think about it.
(swapping the fronts would be ezpz but the older one has less scratches on the top and sides so i need to stick with that one (also the later model has a yellow-ish tint compared to the OG one)
Reply 59867 of 60068, by stmill1
Hi there...
So how far have you been with your Waldorf Microwave unit ?.
One thing I can tell for sure as a musician, this little thing is a beast and is well desserving a "faster" soundcard, aka the DMX6 fire wich is quite cheap today. I'm owning a EWS64XL + the DMX6 fire and it was clearly making the difference when recording and playing in real time. The only thing that became annoying with the time. As my screen resolution got wider, the microwave edit software became hard to use (no upscale function like in modern vsynth).
Maybe I will start to redesign this interface to go on using this synth + check the possibility to use it on W7 W10 & 11. The DMX6 was fine on W7, I need to test it an W10 & 11 but the microwave unit kept loosing connection So I stopped working with it.
Stef
Reply 59868 of 60068, by Law212
Finally got a commodore 64. Well 2 of them and some disk drives. They need a lot of cleaning and I need some cables before I can get them up and running.
Reply 59869 of 60068, by daanmsvl
Law212 wrote on 2026-10-13, 15:08:
Finally got a commodore 64. Well 2 of them and some disk drives. They need a lot of cleaning and I need some cables before I can […]
Great find mate! Dirty: Yeah, but boxed, complete and to be honest, not at all bad looking!!
Out of curiosity: French box, but qwerty keyboard. Typical for Canada? In France they'd have an Azerty keyboard.
Current inventory: 486SX25, Cyrix 5x86 133 MHz, Pentium 75, Laser/2 286 12 MHz and Pentium 166 MMX. Also a Commodore 64 Ultimate Founders Edition! Want to know more? Check out https://vintage486.com
Reply 59870 of 60068, by Law212
Thats a good question. I dont know why its a french only box, but the Serial numbers match from the unit to the box .I thought this was french canadian but maybe its not. I never realized it said imported. Ill have to look int othat more.
Reply 59871 of 60068, by BitWrangler
Sorry no firm ETA on the lot I teased a few days ago, figure end of month.
However, it's weird how sometimes when stuff you are meaning to get round to, appears in a thrift and gets round to you instead...
Inkjet refill mega pack, sealed, just the ticket I hope for some Canon BJ, BJC and maybe a Deskjet I've got stashed. Liked the Canons for being swift and quiet. Think it's a BJ-210 and a BJC-240. And they worked with a lot of stuff from DOS WordPerfect thru Win3.x to 9x. They also perch on a narrow shelf, so not a desk hog. Cartridges in them and spare empties have to be set like cement now, so will probably take a long soak to get them going again. Though I am kind of wondering where the heck I last saw the ultrasonic jewellery cleaner my wife had, maybe sitting them in that would speed things up.
Also got some AV600 powerline adapters, think I can retire the old 85Mbit ones now. Though they might get put on a branch circuit in the basement as a slow 10Mbit service for ISA machines. Not sure if the bottom one is AV600 yet, just came in the baggie with the others. Nice thing on the twins there is that the plug is near the top of the adapter, so they have a hope in hell in sharing a twin socket etc with another plug-in rather than blocking it completely like some adapters, wall warts, wifi extenders etc do.
Reply 59872 of 60068, by Nexxen
Nexxen wrote on 2026-02-12, 16:47:
Capstan rubber band is soft and has become jelly. Same thing as with the Ditto 800 I tried to repair. I measured the rubber part […]
Nexxen wrote on 2026-02-09, 18:01:
Iomega ditto 2gb.
Hoping it works as it's "as is".
Worth 10€ 😀
I measured the rubber part:
height: 4mm
diameter (counting spinning metal thing): 10.5mm
rubber part starting from the metal spinning rod: 2mm
I had a hard time taking these, they could be a little short or not 100% correct.
The only critical part is distance from the metal head/rod.
Edit: the head is the rectangular shaped grey object.
The unit came with a warning to clean with isopropyl every 24 hours of use of the unit, with a cotton bud - vertically; absolutely not horizontally to avoid damage.
Today I dismantled an old printer, before throwing it away, for certain pieces.
I thought I could reuse the rubber cylinders that are used in it and test it as a replacement for the missing rubber part around the capstan.
Results:
1. grooves: the plastic dial in the cartridge literally shaves this rubber
2. it won't work as it also isn't firm enough and I had the good idea not to glue it on the metal directly.
3. it requires a rubber that can withstand up to 80°C (for good measure) and hard enough to not get ground by the cartridge's dial.
Pics
Reply 59873 of 60068, by MattRocks
My first PCI sound card was the original Creative SB Live! 1024 with gold connectors, but there was an earlier even-more-original Creative SB Live! with professional-level backplate featuring "future I/O".
I'd actually forgotten they had two backplates!
Most people never used the future I/O features because most speakers were incompatible, and professionals didn't use Creative. So when I saw one on eBay, I felt compelled to preserve possibly the most successfully marketed feature most people never found a use for 😀
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i7) ] * lost
Reply 59874 of 60068, by Aui
Made an amazing find in the “trash” corner of a local secondhand store. I was seriously considering posting this in the “found in the dump” category, because it cost less than 10 bucks.
The attachment 20261015_075708.jpg is no longer available
I knew immediately that I had discovered something good, but the reality was even better – K7 Slot A Athlon – Never had one - I’m really happy. And it boots up without any issues.
The attachment 20261015_075816.jpg is no longer available
Reply 59875 of 60068, by BitWrangler
MattRocks wrote on 2026-10-14, 20:06:
Woohoo, connector recycling too, can get a straight through cable and blow up not only an apple serial device, but also a bus mouse port, a handful of 99-01 VIVO ports (most used more SVHSish shape ones) and what was the 80s camcorder that had one, Panasonic??? Oh yes, AND a Sega RGB video port.
Reply 59876 of 60068, by oldGPU
G-X wrote on 2026-10-10, 19:27:
Chieftec Dragon is one of my favorite cases of the era. Awesome pickups!!
Aui wrote on 2026-10-14, 23:13:
Sweet find and crazy good price.
Reply 59877 of 60068, by Trashbytes
BitWrangler wrote on 2026-10-14, 23:24:
Blow Up ?
I mean I enjoy sending angry pixies where they don't belong too so uhh .. what other ports have you Blown Up.
Reply 59878 of 60068, by H3nrik V!
daanmsvl wrote on 2026-10-13, 15:43:
Both Gemini and CoPilot suggests that AZERTY was never made for the Commodore 64, and that most localized keyboards seem to have been custom made and with custom character ROMs (even Danish/scandinavian with Æ. Ø and Å)
Reply 59879 of 60068, by MattRocks
Ironically, Creative's future I/O DIN for audio looks a lot like the Creative's Dxr3 DIN for VGA passthrough .. I'll try plugging one in later 😉
EDIT: Oh how absurd, it's an exact match! Creative Labs' Dxr3 VGA-in is physically identical to Creative Labs' future audio I/O. Did any loyal Creative fans of the day notice they could have plugged the output of their Creative Labs' VGA ports directly into their Creative Labs' SB Live audio-I/O to add realtime EMU10K1 environmental echoes to the video signal .. and, if they had two Dxr3 passthrough cables then they could have added Creative Labs' decoded DVD to that chain. Not too sure where the signal would come out, but sufficiently thorough integration testing might have produced something that sounded, looked and smelled like it came from the bathroom! 😁
Creative Labs - the gift that keeps on giving.
