First post, by Unregistered
Error 1904. Module (...path\DiskWriter.dll) failed to register.
HRESULT -2147221160. Contact your support personnel.
This results with, so far as I can tell, all the .dll files in the VDMsound package. I'm attempting to install 2.0.4 to a clean directory.
I'm running a P3 ~600 on an old Intel 440BX board with 192 mb of RAM. Windows 2000, SP2.
Running dosdrv after the install kicks out with the following message:
"Instantiation - COM Error"
Unable to instantiate emulation module 'VDMServicesProvider"
[memory address] - Invalid class string (D:\path\VDMS.ini:66)
Then another one of these, looks like one each for all the .dlls that didn't get registered at first.
Anybody got any clues?
Reply 4 of 4, by Nicht Sehr Gut
You might also check these threads to see if there's any usable info:
showthread.php?threadid=232&highlight=Instantiation
showthread.php?threadid=1360&highlight=Instantiation
showthread.php?threadid=1596&highlight=Instantiation
showthread.php?threadid=1848&highlight=Instantiation
