First post, by CrisGer
HI VOGONS Wizards. I come here when all else fails
I am trying to install and run ROML Riddle of Master Lu on XP SP2 Pro AMD 3300 2/6 Ghz FX 7600 Audigy ZS2....so far no joy
wont install ...set up wont run install wont run...
when i tried using compat 95' and VDMS on the Set up program got this:
Loading "VDDLoader.dll'...
Cache System Enables
32 bit mem avail: 15584488
Available memory: 15601040
FATAL ERROR ENCOUNERD:
VESA Driver not found, please load one and run the game agian
Error code: 0x0600
Code Found in : MASTER.M4E
Offending ESE: I.EXE
Source code index: 00 \video\vidowrap.cpp:13
Path to EXE: C:RIDDLE\
Despcrition:
__InitU
Intallation could not continue!
Either an error occured, or you canceled installation
If you need help, please refer to your mahuals, then if you stil need help....call Sanctuary Woods
I found this thread about someting that mey help but it is from 2004 i am not sure if it reached working condtion:
SolVBE 1.3b release (VESA driver for WinXP/Win2k) by Sol_HSA
any suggestions VERY welcome i have wanted to play ROML for years but just now got a copy....
Admin
3D Worlds and Game Developers Group Linkedin
http://3dworldandgamedevelopers.blogspot.com/
Reply 2 of 8, by CrisGer
OK, I made some progress..i got the installer to run and install a medium install, for some reason the Complete Install option wouild not activate
I detected my sound card and specs.
But i could not run the game. I tried again in DOSBOX to run it and got the following error repeatedly:
FATAL ERROR ENCOUNTERED:
EXCEPTION_THROW: Unhandled expection : EXCEPTION_WRONG_MEDIA
Error Code: OX0901
Code found in :MASTER?M4E
Offending EXE: RIDDLE.EXE
Source Code index: .. \sound\SND_MIDI>CPP:863
Path to ESE: C:RIDDLE\
Description:
1 Specified Driver is Not Loaded
C:|RIDDLE>
I picked Gravis Sound card as a random option..as my FX is of course not on the list. Should i pick another option?
Admin
Reply 4 of 8, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 5 of 8, by CrisGer
thanks so much for the fast posts and i have some excellent suggestions that have come, i forgot about -ioctl and will try that and tweaking the set up settings...
this was what i used....just trying to mount the game directory individually which i do when i am working on a difficult install ....and I like to try to use the default install location i.e. for this one, C:RIDDLE
thanks again so much
these were my mount settings ....i will read the tut you mentioned carefully
as even after years of using emulators i still mess up 😀
Z:\>MOUNT C C:\RIDDLE
Drive C mounted as local directory C:\RIDDLE\
Z:\>MOUNT D D:\ -T cdrom
MSCDEX installed.
Drive D is mounted as CDRom D:\
Z:\>C:
C:\>
C:\>CD RIDDLE
C:\RIDDLE>
C:\RIDDLE>RIDDLE.EXE
and yes i did check the VESA support check box in the properties 😀
Admin
Reply 6 of 8, by CrisGer
Got it working finally. The Snd Blaster 16 setting was crutial, nothing else works, at least none of my other tries did. thanks to everyone for the help, you all are great.!!!
what an interesting game this is, a mix between live action, full motion vid and point and click. Looks as great as its reputatoin. Glad it is still possible to run.
thanks again
chris
Admin
Reply 8 of 8, by CrisGer
sorry about putting that in the wrong section, i will be more careful in future 😀 thanks for all the great help. Very much appreciated.
Admin
