VDMSound 2.1.0 PUBLIC BETA
Reply 46 of 165, by Nicht Sehr Gut
Originally posted by Unregistered Launchpad help file not found? Will this hopefully be fixed?
Until it is, unzip this help file from 2.04 into your VDMSound directory.
    lpadhelp.zip
    11.6 KiB
    1178 downloads
Reply 49 of 165, by HunterZ
Snover wrote:
stop using the "Basic VESA emulation" which causes problems with XPSP1.
Speaking of which, has anyone come up with any theories to explain this? I remember people here on VOGONS thinking I was nuts for claiming this was happening on my computer with programs like Impulse Tracker.
Reply 52 of 165, by SirVincealot
Attempting to download, getting a blank page with this message at the top:
"Could not insert database entry."
What am I doint wrong?
Many thanks in advance,
SirV
Learn to unlearn . . .
Reply 53 of 165, by Nicht Sehr Gut
Originally posted by Niko download not working! eek..... i want it!
SysAdmin moved the message board to a new server, so many links are now broken.
I can't upload it due to timeout issues...
Reply 55 of 165, by Unregistered
Hi. I installed VDMSound 2.1 beta, and the option "Run with VDMS" only shows up when rightclicking .bat- and .com-files, and does not show up when I rightclick .exe-files. The obvious answer is to make a .bat-file to run the .exe-file.
But is there another solution so the "Run with VMDS" would show up on .exe-files too?
B.R.
Reply 56 of 165, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
could you try it with mem.exe located at c:\windows\system32\ (if you run XP that is and have installed it to c:\windows).
If it works there you have not yet tried it with true dos executables (it makes no sense for windows executables to show the "run with VDMS).
Reply 58 of 165, by HunterZ
I believe that Windows EXEcutables have a special header/signature in them consisting of a special sequence of bytes that Windows recognizes and interprets.
