First post, by eL_PuSHeR
- l33t++
Using DosBox 0.58
After issuing the mount a a:\ -t floppy command, i cannot swap floppies. It just works on the first one. If I swap it, I cannot even do a dir command. To use a different floppy, i've got to close DosBox and start from scratch, mounting the floppy drive again. Any help would be appreciated.
