First post, by kardon
I am trying to use DOSBox to install Command and Conquer. So far I have mounted a folder to be my "C:" drive, but I am very computer illiterate and do not know how to proceed further. I have the ISOs for the GDI and NOD disks on my computer, and burned onto CDs.
Reply 1 of 20, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too). Instructions for Mac is on "page" 2.
As you have ISO-images of the disks, you can choose to use the IMGMOUNT command instead of the normal MOUNT command. See the README file for details.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 20, by kardon
I got an "illegal command: win" when I tried to run the install.exe and setup.exe.
I mounted my "C:" drive by typing MOUNT C ~/DOSGAMES after creating the dosgames folder under users/[my user name]/
I mounted my cd by typing "mount D /Volumes/gdi95 -t cdrom
I typed d: to switch to the cd, then dir to see whether there was an install or setup file. There was both, but when I typed "install", "install.exe", "setup", or "setup.exe", I received an "illegal command: win" message.
The version of CnC I have is the free version available for download that was released for CnC's anniversary.
Reply 3 of 20, by DosFreak
Those are all Windows executables. It's likely that that version does not have the DOS install. If it is C&C for Windows 95 then it does not.
A long time ago I uses the expansion DOS files to run C&C 95 and it worked fine.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 20, by MiniMax
Rank Moderator
Moderator
Strange.
SETUP is the program you should use.
Same here. I am attaching the configuration file I used. Adjust the mount commands used, and it should work for you too.
    dosbox.conf
    5.45 KiB
    1038 downloads
    DOSBox 0.73 configuration file for "Command & Conquer - Red Alert" by MiniMax
_________________
Reply 7 of 20, by kardon
I have installed Red Alert instead of CnC Gold, and when trying to play it I get the message to insert the CD in the CD drive, which I did. The game cannot seem to detect it.
I have mounted the C drive and the CD drive.
I have successfully installed Red Alert.
I typed "RA" on the C:\westwood\redalert> prompt, which loads the game but tells me to insert the CD in the CDROM drive. DOSBox can see the CD, but not the game.
Reply 8 of 20, by MiniMax
Rank Moderator
Moderator
Try adding an -ioctl option to your CD-mount command. Or better, use IMGMOUNT to mount the CD-image.
_________________
Reply 10 of 20, by DosFreak
I thought the C&C CD's had CD Audio tracks?
Reply 11 of 20, by kardon
New problem. Unrevealed terrain remains unrevealed when explored. instead, what is left behind is a trail of white because the cursor is white.
Resolution also seems low, but I assume that is normal for games of that era.
Game also crashed when I tried to start a new game after aborting the first mission.
EDIT: screenshot of explored terrain being streaks instead of the actual terrain.
Reply 12 of 20, by MiniMax
Rank Moderator
Moderator
The download is an RAR-archive with an ISO-image inside.
_________________
Reply 13 of 20, by DosFreak
Nice.
Reply 14 of 20, by MiniMax
Rank Moderator
Moderator
Did you install the patch that came with the download?
_________________
Reply 16 of 20, by eL_PuSHeR
Rank Moderator
Moderator
[MOVED]
Why everyone is posting DOSBox related stuff in the DOS (MS-DOS) forum?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 19 of 20, by leileilol
The game had its digital music streamed right out of SCORES.MIX in a proprietary, 22khz 4-bit mono format. Everything up to Tiberian Sun's expansion did this.
