First post, by jwatts21
OS: Windows Vista, 32-bit
DOS-based Software: HYSIM 2.72 (engineering fluid calc stuff)
Situation: This program requires recognition of the security device. The security device is a 25-pin serial port plug-in. It is located on COM1, at this moment.
I can run DOSBox and execute the software, but HYSIM (the app) notifies that it 'cannot locate the security device'. Further, I have "dosbox-0.74.config" with the following settings:
serial1=directserial realport:com1
serial2=directserial realport:com1
serial3=directserial realport:com1
serial4=directserial realport:com1
The security device and software work correctly on a system running Windows NT.
Please, if you can help with security device recognition.
