First post, by Barry_Purplelips
Is there a way to tell which resolution/refresh rate an application is using? taking a screenshot would help with the resolution part, but what about the refresh rate?
Normally I just run the application outside DosBox and check what my monitor switched to via it's built-in settings menu (hoping vga.sys isn't screwing things up) but certain applications plainly and simply won't run on bare XP no matter what.
Thanks in advance.
