First post, by Dule_eluD
Printing (sigh!)
Before I post this, I followed the instructions on that thread, but no luck 🙁
My program supports only LPT1 so I put this line in the config:
parallel1=file dev:LPT1
next, I put in this line in cmd, before launching MB6:
net use lpt1 \\PCName\PrinterName /persistent:yes
but it didn't work, it just issued instructions on how the command works...
Any idea on why that is happening? I'm on win7
and one last Q, is there any way to automate the second line? DosBox doesn't ever recognize the command.
Reply 3 of 8, by DosFreak
If you can find Windows XP drivers for your video card then you can install those and use command prompt fullscreen
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 5 of 8, by Jorpho
This is indeed more of a Windows problem. Maybe you're mistyping something somehow? Is there a line at the top of the instructions saying "the syntax is unknown" ? What do you get if you just type "net use" ?
Reply 8 of 8, by eL_PuSHeR
Rank Moderator
Moderator
Can you try a workaround? Printing to a file (PCL or Postscript or whatever PDL your printer supports [or to a bitmap format, but you will need to convert it to PDL]) and then sending that file to your physical printer using GoPlot Plus
GoPlot Plus is free, btw.
