Retro Rig Photo Thread
Reply 2820 of 3325, by YesAffinity
Intel D865 GLC
Intel P4 2.53/533
2x512MB Geil DDR-333
Antec Basiq Power 450W ATX PSU
1.44MB Floppy
Maxtor 6y160P0 160GB UDMA 7200RPM IDE HDD
Gigabyte GO-B5232A E-IDE DVD-ROM/CD-RW
ATI 9500 128MB AGP
SB Live! Value CT-4870
Windows 98SE
Reply 2821 of 3325, by devius
There's gigabyte optical drives?? 🤯
Reply 2823 of 3325, by YesAffinity
YesAffinity wrote on 2024-10-06, 12:00:
devius wrote on 2024-10-05, 10:42:
Living proof eight there ^ 🤣
*right there
Why van I not edit? I guess I'm too nee to the boards?
Anyway, it works pretty good once I learned/remembered the old lesson that you cant have an optical drive as master on the same cable as a slave hard drive. Well...you can but things don't work reliably.
I also built and added a ps2xpico yesterday. Now that's a neat little device. I now have mouse working in dos.
Reply 2824 of 3325, by Many Bothans
Faceplate looks like it might be OEM'd by Lite-On.
  • Zenith Z386SX-20, 8MB FPM, Video 7 1024i, Unhoused
  • AOpen AP43, Am5x86-133@160, 1MB L2, 128MB FPM, Stealth III S540 32MB Savage4, SB32
  • ITX-Llama, 3Dfx V3
  • Asus CUV4X-E, P3-933, 512MB PC133, Hercules 3D Prophet II MX 32MB, SB Live!
Reply 2825 of 3325, by ratfink
Here's my slot A in the big blue Martian case c. 2001-ish, it takes full length cards, has a handle and opening fan door on the top, and on the door on the front the eyes used to light up softly. It's a bit buried because that build is finished and I've set up the test bench in front of it.
Reply 2826 of 3325, by eesz34
jblang wrote on 2024-10-04, 01:56:
Hi Everyone! By way of introduction, here's my recent build, closely replicating the computer I had during college. I bought the base computer, which came with a crappy Trident 3D Image and no sound card. Added the AWE32 and upgraded to a Voodoo3. Full specs as follows:
There's something so satisfying about the plain beige boxes.
Reply 2827 of 3325, by DarthSun
eesz34 wrote on 2024-10-07, 12:40:
So much that they get yellow. Retro machines are also better to pack in modern black houses because of proper cooling.
Even at the age of 286, I didn't understand how to pack such a modern stuff on such a crappy white house. At that time, modern Hi-Fi stuff was in a minimum of metal-silver.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 2828 of 3325, by eesz34
DarthSun wrote on 2024-10-07, 21:41:
I don't think original Pentiums and older have much problem with cooling. They just don't use much power. And to each their own I guess, but I like seeing the the AT case. For me it's just not right to put this stuff in a modern ATX case (AT systems that is).
Reply 2829 of 3325, by DarthSun
eesz34 wrote on 2024-10-08, 19:34:
The Prescott and Barton configurations are need for good cooling, contemporary CPU cooles and houses were not prepared for this, and the TDP suddenly increased.
P4 in a well -ventilated house:
The attachment p4_win98_open1.jpg is no longer available
For the previous ones, no problem, just ugly, but I have a lot of it 😀
Reply 2830 of 3325, by dr_st
Nice rig.
Contemporary P4/Barton cases still had the PSU on top for the most part, but you could still get properly cooled ones - usually with 1/2 intake fans on the bottom front and 1/2 rear exhaust fans on the top left, under the PSU. The CPU cooler, when oriented properly, would channel the hot air along this route and everything would be OK.
Sometimes you would see additional intake fans on the side panel and/or exhaust fans on the top, but these would typically be excessive. And in any case, those cases weren't white/beige either. I have a silver Thermaltake Lanmoto housing a P4 (Northwood, though) and a black Gigabyte Aurora housing a Core 2 Quad (Extreme).
Reply 2831 of 3325, by DarthSun
dr_st wrote on 2024-10-09, 04:17:
👆 Nice rig. […]
Nice rig.
Thanks 😀
The problem is that the lower in PSU chassis is upper PSU is in the house, the cables are just reaching.
Front side :
The attachment p4_win98_front1.jpg is no longer available
Reply 2832 of 3325, by eesz34
DarthSun wrote on 2024-10-08, 20:25:
The Prescott and Barton configurations are need for good cooling, contemporary CPU cooles and houses were not prepared for this, […]
Certainly P4 is a different animal than the original Pentium. The difference in TDP is roughly 10X.
Reply 2833 of 3325, by YesAffinity
DarthSun wrote on 2024-10-09, 06:34:
Thanks :) The problem is that the lower in PSU chassis is upper PSU is in the house, the cables are just reaching. Front side : […]
👆 Nice rig. […]
Nice rig.
Thanks 😀
Front side :
Very nice! No floppy? I'm considering pulling the FDD from my case. I haven't used it once, and it conflicts with ram slot 4 and seats right against the ram in slot 3. A little electric tape on all corners helps ensure no issues, but it's starting to seem better to just delete it.
Reply 2834 of 3325, by DigiMay
Greetings Vogons! I've been using this site as a source of information for many years but decided I might as well participate as well, starting by showing off my favorite retro build. I have quite a few others now that I can post about later, I wanted to keep this one a bit shorter!
Having been rescued from my grandpa's basement some years ago after it was replaced/discarded (due to a short circuit in the original Vibra 16) I've upgraded it as much as practical whilst keeping the 1999/Y2k vibe going and the core CPU/Mobo pair intact. I've dubbed it "Ath1337" for maximum 90s silliness.
Today it boasts:
  • Asus K7M ATX board with a 800 mhz Slot A Thunderbird Athlon
  • Voodoo 3 3000 AGP + Noctua 40mm fan
  • Soundblaster AWE64 Value CT4380 + SIMMCONN Revival AWE 64 Memory Expansion Card
  • Windows 98SE + UOSP3
  • 120GB SSD + SATA-IDE adapter inside a hotswap bay for easy backups
As well as:
  • 512 MB PC-133 (Running at 100) CL2, Micron
  • Enermax EG375P-VE ATX V1.3 PSU, with plenty of amperage on 3+5v
  • A pair of NEC DVD burners, the last of the functional IDE burners I have.
  • Internal LS120 superfloppy, lacking a bezel
  • Two additional 120G SSDs internally as cold backup, not useful unless I swap IDE cables.
  • NEC USB2 PCI card, benchmarked at around 9 MB/sec in Win98
  • VIA Firewire PCI card, External drive benchmarked around 34 MB/sec in Win98
  • Realtek RTL8169SC Gigabit card, benchmarked around 120 Mbps using Clonezilla Live CD/Samba
The case is a "Ultra Wizard Steel Series" labeled 2006, not exactly the original (beaten up) beige box - but honestly I just think it looks fantastic. I believe it's a knockoff of the Antec cases of the day? I now have the front USB and Firewire ports functional, thanks to some adapters.
Externally I've got quite the setup running too. Peripherals:
(Shared between my 4 primary retro computers via 90s KVM)
  • Gateway EV700 17" CRT
  • Unicomp New Model M PS2
  • Microsoft IntelliMouse PS2/Serial
  • Boston Acoustics 2.1 speakers, identical to what my dad had in the 2000s
(Dedicated peripherals)
  • 8bitdo SN30 Gamepad connected over Gameport via USB4VC Raspberry pi project
  • Handspring Visor Deluxe with USB cradle
  • LEGO Mindstorms robotic kit from late 90s, with serial transmitter
Some pictures! Here's my current "Retro Corner" desk:
The attachment IMG_1068.jpg is no longer available
With Athl337 pictured in an old (cluttered) apartment. It's been cleaned but the PC is mostly the same since these pictures were taken.
The attachment side.jpg is no longer available
The attachment front.jpg is no longer available
The attachment back.jpg is no longer available
The attachment inside.jpg is no longer available
Reply 2835 of 3325, by dr_st
Well, the expansion slots are certainly anything but "under-utilized". 😉
Reply 2836 of 3325, by marcin512
Here's my retro open bench system:
- Streacom BC1 v2
- ASUS P2B-LS (LAN not working 😒)
- ASUS GeForce FX5900
- Intel Pro 1000 GT
- QLogic QLA2200F
- Random 256MB SDRAM
The attachment IMG_2939.jpg is no longer available
Reply 2837 of 3325, by DarthSun
YesAffinity wrote on 2024-10-11, 15:14:
👆 Nice rig. […]
Nice rig.
Thanks 😀
Front side :
Thanks !
In this is none. For example, AMD is in a recreation, but it was not black 😀
The attachment 225621_spxulul0i1ofqogm_1am2_front.jpg is no longer available
[attachment=-1]225621_e9sih4vwa6zwyvkb_1_565_open_rework.jpg[/attachment]
I do not use it, the readability of the old discs is uncertain today. The ODD is more reliable and the flash drive can be used here. And for 386/486 I use GoTek.
Reply 2838 of 3325, by DarthSun
DigiMay wrote on 2024-10-12, 07:02:
Greetings Vogons! I've been using this site as a source of information for many years but decided I might as well participate as […]
Today it boasts:
As well as:
Serious bridgehead!
Reply 2839 of 3325, by DarthSun
marcin512 wrote on 2024-10-12, 08:10:
Here's my retro open bench system: - Streacom BC1 v2 - ASUS P2B-LS (LAN not working :/) - ASUS GeForce FX5900 - Intel Pro 1000 G […]
- Streacom BC1 v2
- Intel Pro 1000 GT
- QLogic QLA2200F
Very professional test table!
