First post, by Ska
Hey
I've got a problem with rayman 1
I had already installed it with dosbox and I played about 3 hours but then suddenly the mscdx was missing. so I unistalled it and when i tried to install it again is says "Theconfiguration programm must be loaded from the cd"
but i have the original cd so what to do ? 😕
Windows 7 (64bit)
Dos Box 0.74
    8.62 KiB
Reply 3 of 5, by Ska
I followed these steps I found in the internet
1. create a foulder called "oldgames" in your hard drive (c:\)
2. open DOSBOX and type:
mount c c:\oldgames
3. type: mount d d:\ -t cdrom -ioctl_dx
4.Type: D:\
5. type: install
Reply 4 of 5, by Jorpho
That looks right, mostly.
When you say that you uninstalled it, did you start over with a completely empty folder?
If all else fails, try making a cue/bin image of the CD (a utility like ImgBurn is useful) and using imgmount instead.
