First post, by bennetag01
I'm trying to run the game pushover on windows 7 via Dosbox
This is what has happened so far...
Z:\>MOUNT C C:\DOSBOX
Drive C is mounted as local directory C:\DOSBOX\
Z:\C:
C:\PUSHOVER>start.bat
then it says insert original disk and try again.....the problem with this is I have got the original disk in. Does anyone know the problem here?
Thank you
bennetag01
    163.28 KiB
    A picture of what has happened so far.
YOU JUST CONTACT THE MAYOR'S OFFICE. HE HAS A SPECIAL SIGNAL HE SHINES IN THE SKY: IT'S IN THE SHAPE OF A GIANT C***!
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Install the game using the same mountings again.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 3, by bennetag01
How do I do that?
Thanks for your help
bennetag01
