PCMCIA Sound Cards
Reply 720 of 734, by Bondi
Cool stuff, Thermalwrong! Thanks for sharing the pics. That's a rare card, i've seen it for sale only once in many years. And quite unique too - the only one to have a built-in speaker. Good to know it uses es1488 chip, will update my chart.
Do you know what kind of connector it uses?
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 721 of 734, by digger
Indeed, thanks for sharing those pictures, Thermalwrong!
Does anybody know if the GAMEjammer is compatible with the WAVjammer (or .WAVjammer), also by New Media?
I'm asking this, because the (.)WAVjammer is, to my knowledge, the only PCMCIA sound card that has native support in a number of later DOS games.
Reply 722 of 734, by Bondi
digger wrote on 2026-05-08, 09:54:
Hey, Digger 😀
Nope, GJ doesn't have native support in games like WJ does. They seem to use different chips. As according to NM website GJ supports 8bit mono sound while WJ supports 16bit sound and also 11 voice OPL2 vs 20 voice OPL2. https://web.archive.org/web/19970118220337/ht … orp.com/gj.html
Not sure why that is, though, as es1488 is a 16bit chip.
Reply 723 of 734, by digger
Bondi wrote on 2026-05-08, 10:39:
Hey, Digger 😀
Thanks, Bondi! 😃
I got a similar answer from Gemini. From what I understood, the GAMEjammer has native Adlib compatibility, but no native DOS support for PCM samples, as the WAVjammer does with at least some later DOS games that used Miles Sound System 3.0 drivers.
Reply 724 of 734, by Thermalwrong
Bondi wrote on 2026-05-08, 05:50:
I have no idea of what connector it uses 😒 I found some pictures of the dongle but nothing hi-res so nothing that helps me.
Here's a decent resolution picture of the connector from the outside:
The attachment IMG_9949b.JPG is no longer available
I've probably got some fine pitch connectors from LCD cables that I can jam in there to get the joystick output working and hopefully I can work out the pinout without opening the card up again. You can see from the connector picture that it didn't stick back together like it did from the factory...
Since the FAQs for the GameJAMMER said it only supports 2 button joysticks, perhaps I should assume that it only supports one joystick, pretty realistic assumption. Then the midi out/in, VCC/GND and joystick pins take up around 8. The audio outputs and inputs should be those pins with the grey SMD components (inductors).
It's got 6 pins in one segment and 9 pins in the other. I think the audio parts are in the 6-pin segment and the joystick is in the 9-pin segment.
I really don't want to take the card apart again and picture the back-side as well if I don't have to.
eh, I did give in and take it fully apart after all. Here's the front and back:
The attachment gamejammer-inside.jpg is no longer available
Here's where my tracing has got me so far, it's a real shame that there's no known pinout for the ES1488 chip:
1	negative of C28, a 16v 10uf capacitor. + goes to 34072.1		no idea yet, maybe line-out, 34072 is an op-amp and pin1 is 1out
2 goes through inductor, resistor, capacitor then ES1488F.1 mic input?
3 goes through resistors R2 & R21, then to ES1488F.6 line input?
4 ground Analog Ground
5 ground Digital Ground
6 goes to XC3042A.24 (VCC pin), also PCMCIA VPP (?) Seems to be VCC
7 through a transistor, goes to LM4861M.1 LM4861M.1 is the shutdown pin. possibly a loopback on the cable possibly to turn off internal speaker
8 through R1 then NE558D.7 joystick axis
9 through R1 then NE558D.2 joystick axis
10 through R1 then NE558D.15 joystick axis
11 through R1 then NE558D.10 joystick axis
12 through a resistor around R8, then to ES1488F.52 Midi I or Midi O
13 through resistor around R8, then to ES1488F.19 (???) Midi I or Midi O
14 XC3042A.23 probably a joystick button
15 XC3042A.22 probably a joystick button
The form factor makes it difficult to test the card while it's open and the laptop's on. Maybe I can use my T2400CS to do that with the palm rest removed. Probably easier to make up a cable though.
Reply 725 of 734, by Bondi
Guys, this is really remarkable. Those who have been following this thread know, that I've been looking for the DOS drivers for REX-5571 card for quite a while. And they seem to be lost.
Yet today we have a fully working DOS enabler for all the functions of the card thanks to our fellow vogoner Zikolas. He used Claude Opus and the TSR made by yyzkevin for a feedback loop from the real harware.
It works on Intel-compatible PCICs and doesn't require CS\SS.
enabler https://github.com/zikolas/rex5571-enabler
more on the tsr https://github.com/yyzkevin/COMrade
https://www.youtube.com/watch?v=GY2T_Da3TiU
Reply 727 of 734, by Bondi
Kahenraz wrote on 2026-07-01, 11:02:
I did a quick Google search and found these drivers. Are they not for DOS?
http://www.win3x.org/win3board/viewtopic.php?t=19261
Nope these are Windows drivers. DOS drivers are nowhere to be found. I tried every possibility, even wrote to the manufacturer several times - the don't have it.
Reply 731 of 734, by nach
Wow, finally!!!!! what an accomplishment!
Roland MT-32, Roland CM-32L, Roland SCP-55, Roland SC-88, Roland MT-90U, Roland PMA-5, Casio GZ-70SP, Casio GZ-50M, Yamaha MU90B, Yamaha MDP-5, Panasonic CF-VEW212, TDK Digital Music Card 9000, Kawai Gmega
Reply 732 of 734, by Bondi
nach wrote on 2026-07-02, 14:33:
Please share you experience, when you have a chance to test it 😀
BTW the project has expanded to other cards with the same chip(es1688). Now MPU port is also available in DOS on rex-5572 via game port(it wasnt working with standard drivers). IBM pcmcia CD-ROM can now produce sound in DOS. Also there is an enabler for Roland SCP-55 that doesn't require CS/SS.
Reply 733 of 734, by nach
Bondi wrote on 2026-07-03, 07:56:
Sure! I will try it when I have some spare time.
Unfortunately I have never had the opportunity to buy a Ratoc REX-XXXX but i have here in a rack the IBM CD-400S and the scp-55 ready for action 😀
