First post, by shorty
Hi dosbox friends ...
I want to play elder scrolls 2 - daggerfall but i can´t operate the right mouse button ...
Does anybody know to fix the problem with daggerfall and the mousebutton 2 ... i tried to set the function on another key but i still doesn't work
also the game everytime must initialize the mouse first in installer to get work
thank you so far
sorry for my broken english
multiplayer? ranking.php?id=7
Reply 1 of 4, by Stingm
Not sure which version your playing but you might try the preconfigured dosbox.74 version at uesp.net in the daggerfall downloads section. If your playing original or free download, this will make a huge difference. Hope this helps! 😉 😁
Sting
Reply 2 of 4, by shorty
It's version 1.07,213
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
you know that you have to press and swing the mouse (while having the mouse button pressed) to attack ?
Water flows down the stream
Reply 4 of 4, by shorty
oops, my fault ...
problem solved
But still I must load the mouse via installer ..
