First post, by Boxtrap
I am new to DOSBox. Just installed DOSBox 0.74 onto a Dell running Windows 7 Enterprise 64-Bit Service Pack 1 with the objectice to run Managing Your Money (MYM) V10.
I am getting the following error: SETUP.DAT not found!
Background.
MYM was sucessfully running in Windows VISTA before being migated to a new Dell with Windows 7 Enterprise 64-Bit
The following directory structure is being used:
C:\DOSBox\MYM\MYMMSTR\
This diretory contains the MYM.EXE application, the SETUP.DAT file and all the respective data files.
The following commands were entereing at the DOSBox prompt:
mount c c:\dosbox\mym\mymmstr\
Response - Drive C is mounted as local directory c:\dosbox\mym\mymmstr\
c:\mym.exe
Response - SETUP.DAT not found!
As mentioned above the SETUP.DAT file is located in the c:\MYM\MYMMSTR\ directory.
I have searched and reviewed any posted MYM threads. Other have MYM running successfully.
Is there something simple I am overlooking?
Any guidence is appreciated.
