First post, by Stormlight
Although I've known about DOSBox for years, this is the first time I've ever used it.
I've been trying to install X-COM from the original floppies I bought back in 1994 because I wanted a clean install. I mounted both my OLDGAMES folder (as drive C:) and my A: drive (as drive A:) in DOSBox. The first diskette installs correctly. But when the install program asks for Disk 2 and I insert Disk 2 into the drive and hit ENTER, the computer reads the disk for a bit and then I get the following error message:
Streaming:(floppy) => (data transfer ...)
Error: file failed to write work file: C\UFO\MPSLABS.$$$
At this point, I get the message to put Disk 3 in the A: drive. Obviously Disk 3 is the wrong disk because the install program has not yet copied the file from Disk 2. If I put Disk 3 in the drive as requested, I get another error message to insert Disk 4 into the drive. Again, this is incorrect because the game came with only 3 disks.
I don't know if this is the Microprose install program or DOSBox that is generating this error. Nevertheless, I cannot get beyond this error regardless of how many times I've tried to install the game.
I've even tried using a USB floppy disk drive, mounting it as Drive B:, but I still get the same error after Disk 1 installs correctly.
What does this error mean, or better yet, does anyone have a solution?
Thank you for any help you might give me.
Dave
[System info]
Motherboard: Asus P5N-D
Processor: Intel Core 2 Extreme X6800 2.93GHz
RAM: 4GB (2x2GB) DDR2 PC2-6400 800MHz
Video card: NVIDIA GeForce 8800 GTS, 640MB PCIE
Sound board: Sound Blaster X-Fi Fatal1ty FPS
Monitor: Alienware OptX AW2210 21.5" HD Widescreen
Operating system: XP Pro SP3
Game: X-Com: UFO Defense
DOSBox version: 0.74
Sound mode used: [X-Com setup] SB16, SBBASE=220, IRQ=7, DMA=1, HDMA=1
Emulator version: [not using any, unless it was part of the DOSBox installation]
