First post, by chmichael
Hello,
Any ideas why SIDVIEW will not run under DOSBOX ?
(Attached the application with a sample file)
    sidview.zip
    75.79 KiB
    192 downloads
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Maybe it's supposed to run from a floppy disk, or maybe it can be reconfigured to run from a subdirectory; but as it is it wants its files in the root directory, so mount the app folder as the root of the C (or A) drive and it appears to be working in DOSBox 0.74 with default settings.
