First post, by exofreeze
When running the software toolworks game Cribbage King / Gin King, both games give the error:
Hardware change or corrupted file. Must re-install program.
I have however run the install program multiple times, and I get the same error each time.
I am using 0.75 with a default conf. I have tried changing cores to normal and cputype to 386_prefetch (for no reaosn other than to see if it would help).
Reply 3 of 3, by peterferrie
can you be more specific about what didn't work?
The QEMM386$ file must be on the same disk as the install.exe, and then you have to run the install.exe again.
after that, the game should work.
