Which Linux on a 486 ?
Reply 20 of 27, by TheLazy1
Maybe when I get a bit more time I'll try a uClibc based gentoo install and see how it runs with the latest Xorg and either fluxbox or XFCE.
Reply 21 of 27, by sunaiac
Do it stage one 😁
Just to see how long it take to compile everything :p
R9 3900X, X470 Taichi, 32GB 3600CL15, 5700XT AE, Marantz PM7005
FX-57/X1950XTX/Audigy 2ZS | Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
i7 980X/R9 290X/X-Fi titanium | Ppro 200 1M | Voodoo 3 2000 | AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 22 of 27, by lcdrugo
I recommend either of these distros:
http://distro.ibiblio.org/baslinux/
http://www.micheleandreoli.it/mulinux/mulinux.html
Both are very simple, run fine on a 486, and can be installed from floppies.
Reply 23 of 27, by Jorpho
feipoa wrote:
There seems to be no way around editing the config file for the graphics if you are going to use an X-Windows systems on an older distro, at least for my setup there wasn't.
It is inevitable even now, is it not?
http://xkcd.com/963/
Reply 24 of 27, by MobyGamer
Shodan486 wrote:
A little sidegoal though - just want to see how the 486 i'm using is able to handle various multimedia stuff in linux environment, playing mp3 plus browsing net etc...
Well, I can answer that for you right now. A 486 is just barely capable of playing back an MP3 since the calculation is floating-point heavy. The advent of the Pentium is what popularized MP3 because the floating-point performance was that much better. If you play an MP3 on a 486 and then try to do anything else, the audio will start to skip or pause.
There, I just saved you from having to install a unix distribution 😀 Although if you were still bent on doing so, FreeBSD 2.2.9 (ancient) is very snappy and runs on 386s and higher, and comes in a 1.44MB floppy distribution (although many newer versions have a dual-1.44MB floppy distro that you boot and then install the OS over the internet). If you need a link to 2.2.9 let me know.
Reply 25 of 27, by Hatta
IMO, the best reason to put a UNIX on one of these old machines is to have tools like dd, parted, rsync, wget, etc to back up and test various configurations. Like he said, I wouldn't want to use it for MP3s, etc, especially with VBR being standard these days.
Reply 26 of 27, by Jorpho
Well, there are MP3 players for DOS. DOSAmp, for instance dates back to that era.
Reply 27 of 27, by MobyGamer
DOS, Linux, etc. aren't the limiting factor -- a 486 is. IIRC you need roughly a 486/100 to play back an MP3. Here's someone trying to get a 386-40 to play back an mp3 and he can only do so at 16KHz: http://www.youtube.com/watch?v=6Jj97NXgHw4
