First post, by badmojo
I have this MPU card:
It's Roland MPU-401 compatible Music Quest MQX-32M, and does work in "intelligent mode". I've used it successfully with several games (Ultima 7, Gateway, Lost Vikings, etc, etc). But Wing Commander 1 hangs, and I've isolated the problem to this card. The game loads, my MT-32 lights up and displays all the right messages, the music starts and the opening sequence begins, but at varying times during the firework animations the game freezes. It works fine in SB mode, or with a real Roland IPC, and I've reproduced this on 2 different machines (a 386 and a 486).
Music Quest provide a diagnostic tool which does several things, and the documentation specifically talks about "intelligent mode" DOS programs, from the doco:
"MIDI Metronome (MQX-32M, PC MIDI Card)
For "intelligent mode" Dos programs only, this feature instructs
the interface to send out MIDI messages to an instrument to act as a
beat reference.
Channel Remap (MQX-32M, PC MIDI Card)
For "intelligent mode" Dos programs only, this feature allows changing of
channel numbers on received MIDI data.
Channel Split (MQX-32M)
For Dos programs which are not MQX-32M-aware, this feature allows MIDI
playback data to be directed to one or both MIDI ports on ths basis of
channel number.
Dropout Control (MQX-32M)
For Dos programs only, this features allows the specification of the amount of
dropout protection -- "freewheel" -- used when the MQX-32M syncs to SMPTE."
I'm wondering if perhaps the Wing Commander issue can be resolved by altering these settings, but I don't know enough about the nature of MIDI, and what Wing Commander might be looking for that it's not getting.
For example I've played around with the metronome settings and I thought I saw some improvement, but I might just be imagining things. And there are several different variables involved so a methodical test of them all would take forever.
So my question is for someone who understands more about "intelligent mode" - do any of the settings above look like they might be worth playing around with? Or is it simply a case of "either it works or it doesn't"?
Reply 1 of 14, by vetz
I don't have much knowledge on these devices beside from what I've read on Vogons and from my Midiman device. I've actually tried Wing Commander 1 on my MM-401 and it works without problems. There were another post here on Vogons not long ago with someone saying that the intelligent clones are all not 100% compatible in all games.
EDIT: Nvm last sentance, it was you who posted it. 🤣
Reply 3 of 14, by badmojo
🤣, yeah I'd decided just to let it go at that point but I just can't seem to do that with these retro hardware problems, they haunt me!
And it's a rev 0 MT-32.
Reply 4 of 14, by Great Hierophant
Maybe the issue is confined to the rev. 0 MT-32s, perhaps the interface is too fast for the firmware, causing the crash.
Reply 5 of 14, by badmojo
Maybe so, and there's nothing I could do about that I suppose. Wing Commander does have speed issues as we know.
I've requested registration on the Quest Studio forums too - I notice you're already a member GH. Maybe it's more a question for those guys.
Reply 6 of 14, by chrisNova777
http://www.oldschooldaw.com/forums/index.php? … msg2719#msg2719
(the chart is what im trying to post here, comparing the music quest card to voyetra card, to the cms card)
i pulled out an ad for an earlier MIDI interface known as the CMS-401
which was another clone by another company called Computer Music Supply
they made a number of different interfaces but this was their only mpu-401 compatible clone model
ad u can see the comparison chart from the ad.. it was claiming that it had these features
that the other cards did not have..im fairly certain the MQX-32M was a 2nd revision of the original MQX-32 (non-M)
and i believe it was this competition which drove them to add these extended features u have posted about
above in order to compete directly with Voyetra + CMS.
not sure if u understand what those features are for above but they definately are more to do with composing + playing music
MIDI Metronome - for syncing drum machines
Channel Remap - for changing on the fly what instruments are being triggered from an external sequencer
Channel Split - for layering more than one instrument/module patch to thicken up sounds, layering drums or synth sounds
Dropout Control - this has to do with syncing the sequencer to REEL TO REEL tape via SMPTE time code
(which is a set of clicks or beeps usually being fed from 1 track on the reel of tape out into the the appropriate RCA input jack on the backplate of the card)
this is how music was still being made untill hard disk recording hit the mainstream in around 1994/1995. the dropouts occurred when people were using crappy or old tapes http://searchstorage.techtarget.com/definition/dropout so this is just to adjust the built in feature to keep things in sync in case the smpte track screwd up momentarily so unless u were feeding a SMPTE track into the input on the back of the card this has nothing to do with the bug.
i just bought one of these cards its being mailed to me right now which is why im responding to this thread..
badmojo: did u try using the same default BaseAddress + IRQ as the MPU-401? that may be a requirement for
proper "mpu-401" mode use with wing commander?
i was just talking with keropi and he mentioned that this card is "Buggy with games" but i have to say thats an assumption
that logically stems from the fact that this card has extended ports (2 instead of 1) functionality + extended MIDI Channels (32 instead of 16)
over the PC MIDI card.. so of course the PC MIDI card "just works" and has "no issues"....
there must be a way for the mqx-32m to function properly.. the earlier comment about revision of the mt-32 has no relevance to this.. as the midi data only flows in one direction. out of the card and into the mt-32 there is no data returned from the mt-32 unless u hooked up 2 midi cables? and even then that wouldnt cause the game to freeze.
there are applications to visually record the midi output from the card.
im curious to try to discover the real cause of the bug..
im also curious if anyone has ever seen one of these CMS-401 because i cant find anything on these cards except archived in magazines
i saw some notes about the version of the chip/rom on the card having an impact? was that related 100% to the bug discussed here?
can anyone remind me as to the dtails of that?
anyways ill soon have my mqx-32m so ill be able to do some testing once it gets here.
Reply 7 of 14, by Cuttoon
Good news everyone, I just snagged this one:
http://www.ebay.de/itm/231814784741
NOS, still wrapped in plastic.
And apart from that oldschoolaw page you linked to, all I had was the promise that it's Roland compatible, here:
http://nerdlypleasures.blogspot.de/2010/03/tu … land-mt-32.html
I could post some pictures or answer questions, but tbh, I'm really new to the whole MIDI stuff.
I like jumpers.
Reply 8 of 14, by dnewhous
To use a metronome signal on a MIDI cable, they would have to use a no connect DIN. I don't see any of the PC sound modules supporting a MIDI sync connector, so I am confused. https://www.midi.org/specifications/item/midi … l-specification
There were early drum machines with such a connector.
TR-808, Sync, 1981
TR-606, Sync, 1982
TR-909, MIDI+Sync, 1984
TR-505, MIDI, 1985
TR-707, MIDI+Sync, 1985
TR-727, MIDI+Sync, 1985
TR-626, MIDI, 1987
Daniel L Newhouse
Reply 9 of 14, by yawetaG
dnewhous wrote:
To use a metronome signal on a MIDI cable, they would have to use a no connect DIN. I don't see any of the PC sound modules sup […]
TR-808, Sync, 1981
TR-606, Sync, 1982
TR-505, MIDI, 1985
TR-626, MIDI, 1987
The sync feature predates MIDI. What you're looking for is MIDI clock, probably.
Reply 10 of 14, by Cloudschatze
What is it that you think a "PC sound module" should be doing with either DIN sync signals or MIDI clock messages? These signals/messages are used to synchronize disparate playback tempo clocks. The Roland MT-32, for example, has no such playback clock or prerequisites - no internal sequencer, no drum machine, no tempo-driven beats or effects - it neither uses nor requires the synchronization that DIN sync and MIDI clock provide, and lacks the physical interface to support the former besides.
Reply 12 of 14, by chrisNova777
cuttoon; is there any chance you can post some high quality images of the CMS 401 interface?
theres a serious lack of info on that interface online
Reply 13 of 14, by Jepael
The only pictures I've found make me think it uses licensed Roland chipset. Better images would reveal it.
Reply 14 of 14, by Cuttoon
So sorry I forgot about all this.
Still have the CMS-401 II.
Still someone listening in here?
Photos of card and box. In what I'd consider "high res" for internet standards.
(Not sure what this forum supports as attachments, don't like upload portals for linking too much, but recommendations welcome.)
4th Chip didn't quite make it in the picture, it reads
RCA X
CDM6116 AE2
441
Card came bundles with cakewalk 5.0 for Dos on 5.25 and 3.5
There also was something really weird and boring. A hardware manual. Enjoy.
Quick & dirty pinout test for the db9, using a buzzer:
1st hit counts, I don't know MIDI cabling by heart, figure it out yourself. If inconclusive, please ask. I'm really bad at drawing and mirroring things in my head 😉
Pin count is fltr 1 through 5 and 6 through 9, looking at the female db9 plug on the cable and clockwise 3, 5, 2, 4, 1 on the female DINs.
(plug designations according to manual page 4, min1, min2, mout1, mout2)
1 on the db9 goes to red DIN, mout1, pin 5
2 - mout1, 4
3 - mout1, 2 and mout2, 2
4 - min1, 5
5 - min1, 4
6 - mout2, 5
7 - mout2, 4
8 - min2, 5
9 - min2, 4
    cms_401_II_manual.pdf
    1.15 MiB
    37 downloads
    119.28 KiB
    184.17 KiB
    255.57 KiB
I like jumpers.
