Dosbox "Fatal Exception" with Windows 95
First post, by jspyder
I'm installing Windows 95 on Dosbox (Windows 7 Pro host system). As it's setting up the Control Panel, I am consistently getting a "fatal exception 0E at 137:BFF9A07C" error. I have tried disabling things (like the sound card and NIC) in the configuration, but nothing has worked so far.
When I ran it in Debug mode, it identified "IRET: illegal descriptor Type 125 Int 15 BIOS" which suggests that it's running into an IRQ problem (maybe? I'm great with Windows, not so great dealing with hardware).
Help?
Reply 1 of 25, by leileilol
Try booting in safe mode and delete/disable the "Plug 'n Play" device in Device Manager. It should let you do this even when you don't complete the install.
Also cputype=pentium should help as well.
long live PCem
Reply 2 of 25, by jspyder
I tried "Pentium", but that didn't help.
How do you get into safe mode from Dosbox? I can do it from BIOS on a non-virtual machine ...
Reply 3 of 25, by leileilol
Hit F8 when it says "Starting Windows 95..."
long live PCem
Reply 4 of 25, by jspyder
Oh, I forgot about THAT way ...
... Didn't work ...
(Love your signature line, BTW ... )
Reply 5 of 25, by robertmo
cputype=pentium_slow
Reply 6 of 25, by jspyder
I *had* cputype set for 486, but tried Pentium_slow anyway ... no change, still getting the error ...
Reply 7 of 25, by robertmo
whole installation had to go without single error, and you need powerful pc
Reply 8 of 25, by jspyder
The original processor is an AMD Phenom II X4 925 2800Mhz with all cores activated ... ? I didn't change the processor type in the configuration until I started to have this error ...
Reply 9 of 25, by robertmo
Pentium_slow (or pentium depending on the svn you use) is a must, no other possibility. you have to reinstall i guess
Reply 10 of 25, by jspyder
Actually, by booting into safe mode and removing all of the possible problem children from Device Manager (in system devices and sound, video and game controllers) I was finally able to boot to the desktop ... where it freezes with a constant hourglass.
I *think* it's one of the devices that's causing the problem, and am pursuing it on that end, and will continue to update this thread as I go.
By the way, the Dosbox console reported that Pentium_slow was an invalid configuration choice, and automatically changed it to auto.
Reply 11 of 25, by robertmo
Reply 12 of 25, by leileilol
Also, the "S3" driver provided by Windows 95 will crash too. Suggest switching to VGA and downloading a s3 trio 64v+ driver.
long live PCem
Reply 13 of 25, by jspyder
Robertmo: Did you happen to miss that I reported:
"By the way, the Dosbox console reported that Pentium_slow was an invalid configuration choice, and automatically changed it to auto."
Reply 14 of 25, by jspyder
The video driver was the culprit. I changed it to Standard SVGA, and it booted up just fine.
Now it's just a matter of tweaking and experimenting (Yay!).
BTW, can anyone suggest a way to access files through a Dosbox Win95 machine? If I burn a CD, 9 times out of 10 it won't read it in Win95 ... grrrrr ... and Win95 doesn't recognize USB (never has) ... and I don't have a floppy on my current machine (motherboard doesn't even have an IDE controller) ... and it won't recognize the NIC on the host machine ...
Reply 15 of 25, by kekko
I suggest you to use Win98 instead of Win95; in my experience you'll get much less troubles, probably due to newer drivers. Win98 bundled video drivers always worked fine.
Set cputype=pentium_slow and cycles=max for the best results. Use these option for installing AND for running windows.
At this moment there's no way to transfer files between host and guest machine with dosbox. I use Winimage to edit disk images.
Reply 16 of 25, by jspyder
Not meaning to cross talk or incorrectly start a new thread, but:
You mentioned Winimage, so I downloaded it and tried to load in the image file I'm using for DosBox. First, it doesn't show any files at all, even though it has the complete Win95 OS on it; secondly, if I try to import a file or folder, it keeps telling me that it can't because the "image is full" (while the properties for the image show almost 2GB free).
Have you ever run into that? And do you know if it can be corrected and,if so, how?
(And please see my comment to Robertmo re: "Pentium_slow" ... )
Reply 17 of 25, by NY00123
Wait, can't you set cputype=pentium_slow?
Which version of DOSBox are you using at the moment?
Reply 18 of 25, by jspyder
Dosbox Megabuild 6 - it was the only way I could find to effectively solve certain inherent problems, especially ones involving booting from an image.
Reply 19 of 25, by kekko
so you're asking support for a custom, 3yrs old build, right?
please try the latest official dosbox build.
Read the enclosed readme file and the wiki/guides available for using images.
