First post, by Destajador
Hi all!
A easy question, I see this cmd at the time i want to add a serial port:
serial1=nullmodem transparent server:192.168.0.10 port:10000
I get connected to the ethenet to serial device, but for some reason I can't make the software works with the device connected at the remote serial.
I test several converters with the same results. I test too with a null connected at the remote device and a VC100 terminal, it works but for some reason not with the application that I must use.
With USB adaptors works great.
It's RAW protocol this virtual serial? I mean it's a transparent connection?
Can I set the RTS or DTR lines manualy? O r don't take care about others flow control?
Best Regards
Destajador
