First post, by Russotauchen
Hope somebody has a hint to resolve this:
When using ALT + Enter to enlarge the DOSBOX to full screen, I have an off-set to the left and as a consequence the promt is only partially visible,-
in fact we cannot use the full screen mode.
I have a terra screen from 2012, operating WINDOWS 7 in the background. Changing the resolution of the screen does not resolve the problem. I should be grateful to professional advice, how to get rid of this problem. best regards to the community, Russotauchen, Switzerland
Reply 1 of 1, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Try a different output in the exult config (surface, overlay, ddraw...) and an up to date graphics driver from the chip maker
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
