First post, by mperelman
Another command, shift-f10 is also not working. I uninstalled Dosbox, reloaded it, but that does not work.
Any suggestions would be appreciated.
Thank you.
Michael
Michael Perelman
Economics Department
California State University
Chico, CA
95929
530 898 5321
fax 530 898 5901
http://michaelperelman.wordpress.com
Reply 2 of 3, by mperelman
Full screen is finally working. As far as I know, I did nothing to make it stop & nothing to make it start again.
However shift-f10 (not control) is a very important command in my ancient outliner, which is my core program.
Even if you cannot help me, I am very appreciative for all the help people here have given me. Without it, my tablet would have lost most of its value.
Michael Perelman
Chico, CA
95929
530 898 5321
fax 530 898 5901
Reply 3 of 3, by fillosaurus
@mperelman
Sir, just an advice from a fellow forumist... Do not give away your real ID, phone/fax number and webpage. In short time you will receive a lot of scam calls, mails, etc.
I know this from personal experience. If you value your privacy you would alter your signature.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
