new shaders for dosbox?
First post, by jim78b
where i find new shaders for dosbox?
the bnes emulator shader are right for dosbox?
i need a crt shader....with blurring +
best regards
Reply 1 of 4, by kolano
Unfortunately the BSNES shaders won't work with DOSBox. They use an XML format, that doesn't seem to be that widely supported by other emulators. I've been hoping for a DOSBox compliant version of the xBR shader for a while myself. Looks like you already found the threads with info on DOSBox compatible shaders though.
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 2 of 4, by jim78b
Lucky you, who are skilled in programming. then browsing the forum I should find something about? i want a better crt emulation!
best regards
Reply 3 of 4, by kolano
I'm pretty sure the Yhkwong build already comes with at least 2 CRT shaders. I'm guessing there are at least a few others scattered around, including a few in the CRT shader thread you had also posted in.
Reply 4 of 4, by jim78b
ok Thanks very much. i told you so because the only 2 crt filters Are very slow in some games
