First post, by f00dl3
f00dl3
Offline
Not sure if this is a problem in regular DOS Box or if it impacts only the Mobile "DOS Box Turbo" version -
having an issue where once I have C drive mounted off "dos.img", every time I attempt to mount any CD .ISO image, DOS Box then locks up on the next program launch / command entered. Duplicated this several times. Just wanted to see if it's a incompatibility in launching an ISO once an IMG is already mounted, or something specific to the "port" I'm using.
