First post, by truth_deleted
[Edit: I confirmed that SDL defaults to directx video and audio. Therefore, the only advantage of the attached builds is that a directx6 function is available. However, the single directx6 function is not used by dosbox. Therefore, the attached files probably won't be of use. I left the prior message below.]
The SDL library has a choice of Windows audio devices: dsound or waveout. Dsound refers to the DirectX sound component. To enable the DirectX sound functionality, the SDL library must be compiled with specific DirectX header files.
I compiled three versions of SDL.dll (attached files). One is for WaveOut. The other two SDL.dll files are dsound capable. One has the typical DirectX5 sound while the other has an additional DirectX6 sound function.
    SDL_kit.zip
    513.77 KiB
    32 downloads
    SDL.dll files for enabling directx sound
Reply 2 of 2, by truth_deleted
ykhwong wrote:
Is there a diff/patch that can be applied to SDL for the DirectX6 sound function?
Attached; difference is a definition line to activate the code for the DirectSound notify interface (dx6). My impression is this provides a streaming buffer for audio; but internet posts suggest this buffer is slow and not useful.
    dx6sound.diff
    388 Bytes
    22 downloads
    SDL directx6 sound patch
