First post, by TELVM
· VRMin · · · · · 4x Chemicon KZE 1200uF 16V 10mm ===> 4x Nichicon HM 1800uF 16V 10mm
· VRMout · · · · 7x Chemicon KZG 1500uF 6.3V 8mm ===> 11x Nichicon HN 1800uF 6.3V 8mm
· Smaller caps · · · Whatever 1000uF 6.3V 8mm ===> 16x Panasonic FR 1000uF 6.3V 8mm
· Smaller caps · · · Whatever 100uF 100V 5mm ===> 10x Rubycon ZLH 100uF 16V 5mm
5tvoux7wqjxkjgtg6htu_thumb.png Recap_P4_P800_005.jpg Recap_P4_P800_006.jpg Recap_P4_P800_009.jpg
Recap was a success and the mobo works like a charm.
Let the air flow!
Reply 1 of 28, by JaNoZ
You are not going to tell me you also replaced all those smaller caps also, the pana fr and the zlh caps are already excellent caps and cannot believe they were bad.
The cpu power supply caps may have been the only bad ones out there.
Reply 2 of 28, by TELVM
The Panny FR and Ruby ZLH are replacements for the whatever smaller originals.
This mobo worked OK and visually al caps looked good, but there was the occasional cold boot restart, so I decided to replace the whole shebang.
Let the air flow!
Reply 3 of 28, by Mau1wurf1977
Very nice job!
The sheer amount of caps on these boards is amazing. Makes recapping quite a bit of work and not cheap.
My YouTube channel
Reply 4 of 28, by Logistics
Very nice! Those are lovely looking caps. This brings back memories as I recapped my entire P4PE, but I used polymer caps. Recaps definitely give these boards life they didn't have, new most notably due to improved capacitors for the CPU and RAM stages.
Reply 5 of 28, by TELVM
Thanks. I considered polys but ultimately went for lytics, cheaper and more retroish.
While I'm at it I've beefed up my homebrew VRM heatsinks:
t905105_P4P800HeatsinksDIYB001.png t905106_P4P800HeatsinksDIYB002.png t905108_P4P800HeatsinksDIYB004.png t905109_P4P800HeatsinksDIYB005.png
Unlike fancier versions like the SE or Deluxe with three mosfets per phase ...
... the base model P4P800 has to do with only two per phase, and they get fiercely hot while feeding an OCed Preshott.
Let the air flow!
Reply 6 of 28, by Mau1wurf1977
Could you please expand in this? Are there benefits to using polymer?
My YouTube channel
Reply 7 of 28, by borgie83
I just bought a new and sealed Asus P4P800 SE on eBay for $70. There's also a seller selling new open box ones. Good job though. Looks great! I've got a Gigabyte GA-6VTXE that needs to be recapped. I've already bought the capacitors but I'm a little scared about doing it myself because I'm not that good at soldering and everyone on YouTube makes it look easy 🤣
Anyone here in Melbourne, Australia want to help me out? 😀
Reply 8 of 28, by Logistics
Polymer are extremely low-impedance and have very good ripple handling. A socket 478 doesn't necessarily need polymers, but I had a mess of them so I used them. If you plan on overclocking then I would suggest using them in the VRM and RAM stages to keep things stable.
Reply 9 of 28, by TELVM
Excerpt from Capacitor Lab - Polymer Caps:
Benefits of Polymer Capacitors Polymer capacitors are characterised by lower ESR and ability to handle higher ripple […]
Polymer capacitors are characterised by lower ESR and ability to handle higher ripple current than their wet electrolytic counterparts. They are also characterised by not changing their ESR when their operating temperature changes and also having a much longer life. Sanyo quotes a 10 times increase in lifetime for a 20degC reduction in operating temperature for their OS-CON polymer capacitors whist a wet electrolytic capacitor in comparison would increase lifetime by 4 times.
Low ESR
Low ESR is so important in electronics because the lower the ESR the faster the capacitor can discharge. This is a great benefit because it means the capacitors can respond faster to large current transitions. However there are several wet electrolytic capacitors which offer similar ESR as their polymer counterparts.
High Ripple
The high speed power delivery to the latest CPUs subjects the capacitors in the VRM to high ripple. This is why you will see polymer capacitors more often on vcore output on the latest motherboards as they can handle much more ripple than wet electrolytics ever will. Failure of electrolytic capacitors on vcore output can be partly attributed to exposure to ripple current that was beyond their specification.
Notice that a decent PSU providing stable voltages within ATX specs and low ripple is also a critical part in the equation. A piece of junk/old and tired PSU with cheap/bad caps flogging our mobo with out of spec voltages and high ripple will murder the best caps on the best mobo.
Let the air flow!
Reply 10 of 28, by Skyscraper
This is how it looks around the CPU socket on my Asus P4P800.
The larger caps seem to be United Chemi-con KZE like on TELVMs board . Are these good caps quality wise?
The smaller caps I cant identify. Perhaps someone can help me?
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 12 of 28, by Skyscraper
NJRoadfan wrote:
The smaller caps next to the CPU socket are Panasonic. The boxed "M" is their logo. Good stuff.
Good to know
Thanks!
Reply 13 of 28, by jwt27
Nice job you did there! I also have a recap planned, for my MS-6119 board. Need to find a cheap source for these Panasonic caps... Mouser looks like the place to be.
It's the Matsushita logo, actually 😉
WANTED - Manuals/drivers for:
  • Tecmar Graphics Master
  • Paradise Autoswitch EGA 350 (EGA1A)
Reply 14 of 28, by TELVM
Skyscraper wrote:
... The larger caps seem to be United Chemi-con KZE like on TELVMs board . Are these good caps quality wise?
Yes and no. Post 2006 or so ones are good. But back in the time when these boards were made the KZE and KZG series were plagued (some production problem they later identified, apologized and solved).
They look OK but I'd keep a suspicious eye on them ...
Panasonic FJ, top-notch caps as good or better than the Ruby MBZ. The 'M' logo comes from Matsushita, the founder of Panasonic. The 'T' vent pattern is a giveaway.
I envy the nine mosfets in your Deluxe 🤣 .
Let the air flow!
Reply 15 of 28, by Logistics
This man speaks the truth! In fact I did a complete recap of the PSU with Panasonic caps to complement the P4PE. I still look back on that system with fond memories.
Reply 16 of 28, by F2bnp
This is an amazing motherboard. I have a P4P800 SE that is apparently dying, it powers up only when it feels like it and I don't see any cap damage. Tried different RAM/CPU/GPU and PSU, but it is merely random when it powers up.
Any suggestions?
Reply 17 of 28, by Skyscraper
Any suggestions?
The Asus socket 478 boards are very picky when it comes to memory
If you only have tried some modules. Try a few more.
Try memory that can handle cas 3.
I have had issues with boards defaulting to cas 3 even when Winbond BH-5 memory has been used resulting in a system that wont post.
(In that case it wont be random though. It just wont post)
Exept beeing picky about memory the P4P800 is a nice and rock stable board.
Diffrent earlier Asus P4B533 boards have been a bit like you described but once you get them going they usually work until they loose the bios settings.
Your issue sounds a bit like problems with caps 😒
Reply 18 of 28, by vetz
May I ask what is the big deal with this motherboard?
At my work I'm throwing away loads of Socket 478 systems/boards. Don't see the purpose of keeping more than one or two. Thought they had no sale value.
Reply 19 of 28, by NJRoadfan
If you have a high end AGP card that you want to use for some reason, the high end last gen. i865 boards are the ones to go for. I personally have a Gigabyte GA-8IPE1000-G Socket 478 board to run a AGP capture card, but only because it was never made in a PCIe version.
