Reply 30260 of 31464, by DarthSun
RetroBus wrote on 2025-10-09, 02:31:
Oh Wow! Thats awesome! puts my find to shame 🤣. Those bigger external ones must be even rarer these days, I think I have only ever seen one on marketplace
I bought it a long time ago. On an online marketplace here. I found a photo after the purchase.
The attachment a2ppro1.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 30261 of 31464, by Muckrake
Successfully patched Bitmap Bros' Xenon to run in 16 colors on an IBM PCjr.
Reply 30262 of 31464, by wbahnassi
Good reads while waiting for the pizza order to come out in a rainy night.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 30263 of 31464, by sunkindly
wbahnassi wrote on 2025-10-10, 00:20:
With those colors, that place looks very Sound Blaster compatible haha.
SUN92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN97: QDI Titanium IE | Pentium MMX 200MHz | Tseng ET6000 | SB 16
SUN00: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
Reply 30264 of 31464, by sunkindly
Just when I told myself no more computers, a Cyrix 5x86 has appeared (still figuring out that pesky MHz display). Still debating whether I want to go with a POD in this machine, but this is my first Cyrix so I'm already becoming fond of it.
The attachment IMG_7288.jpg is no longer available
Reply 30265 of 31464, by RetroBus
A recent acquisition sunkindly? Im trying to limit new things also (running out of space), but there is no way I would resist that!
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 30266 of 31464, by sunkindly
RetroBus wrote on 2025-10-10, 07:06:
Yeah! I originally wanted a board with VLB for more historical flavor but figured I might as well just get something I can use my ET6000 with since it was displaced from my Pentium III build.
Reply 30267 of 31464, by Living
sunkindly wrote on 2025-10-10, 06:22:
Wild Cyrix appeared!
sunkindly: no more computers!
its not very effective...
Reply 30268 of 31464, by sunkindly
Living wrote on 2025-10-10, 19:50:
Wild Cyrix appeared! sunkindly: no more computers! its not very effective... […]
Cyrix used QUAKE!
Cyrix hurt itself in confusion...
Today I went to go make sure the cooling is all good to go before I run it at 120MHz consistently (the CPU came with the mobo) and to my pleasant surprise it's the IBM variant!
Also yes it says Socket 2 which further solidifies me wanting to really make this an oddball build.
The attachment IMG_7291.jpg is no longer available
Reply 30269 of 31464, by AndrettiGTO
bjwil1991 wrote on 2025-10-06, 02:33:
Installed sockets for the following on my IBM 5150 board: […]
P8284A clock generator chip (mine might be faulty and I did the socket so it can be swapped on the fly)
Bank 0 RAM + bit pairty for Bank 0 (so they can be swapped easily)
I still get the continuous beep, which means the 8284 is most likely dead as a hammer or the RAM is dead. Either that or U33 (BIOS) is bad. When I get the EPROMs, I'll do the diagnostics ROM first and see if it boots up with that and if it does, then I'll do the GLaBIOS ROM and go from there. If it doesn't boot with the U33 swapped, then I'll have to replace the P8284A with a new one and if it boots up, then it's fixed entirely and I can get it all set up with an ATi EGA Wonder 800, Sound Blaster 2.0 w/ CMS upgrade, AST SixPakPlus SPK-384 upgraded to 576KB RAM, XT-FDC card, and XT-CF connected. I'll have to figure out how to hook up the internal speaker header to the sound card, but that should be just a 4-pin header and only solder on the audio part from the header to the mic input on the sound card. Either that or figure out a better way since there is no PC speaker header on the sound card itself.
One of my 5150s had bank zero issues so installed sockets on 2 of the DRAMS. Found it difficult, desoldering with thoes thick boards and ended up having to repair multiple pulled traces.
Sounds like you'll soon have success with yours.
It's all fun and games 'till someone loses an eyeball
Reply 30270 of 31464, by ubiq
My Athlon XP 2600+ system gave me a scare - started powering off by itself when under load (or sometimes bluescreening), requiring a hard reset of the PSU's physical power toggle switch. I was worried my Radeon 9700 Pro could be dying, but I think I've narrowed it down to it just taxing my modern Corsair PSU's 5v capacity. Putting it on its own dedicated rail seems to have settled things down. Took the opportunity to add a couple 120mm fans to the case - sure, the added noise defeats the purpose of the passive cooler on it, but I kind of don't want to take any unnecessary chances with this card.
The attachment IMG_3133.jpeg is no longer available
The attachment IMG_3135.jpeg is no longer available
The fans actually came with a little in-line speed control adjustment, so I could set them to low and they're still pushing plenty air: 👌
The attachment IMG_3132.jpeg is no longer available
Reply 30271 of 31464, by sunkindly
A rant / activity hybrid but I went to buy something for one of my builds on eBay and apparently I've been blocked. I bought a card from them and returned it a couple of months ago, but it went smoothly and I even left positive feedback. I never spoke to anyone directly, I just went through the automated return process. Super bummed because they carry a really decent stock. I even have them as a saved seller. Why offer returns if you're just going to block a customer for it?
Reply 30272 of 31464, by roxfly
ubiq wrote on 2025-10-11, 02:44:
My Athlon XP 2600+ system gave me a scare - started powering off by itself when under load (or sometimes bluescreening), requiri […]
The 9700 Pro should use 12v. The extra power is a 12v plug.
It could be GPU overheat powering it off, if that is what is happening.
Faulty mainboard capacitors could also be why it powers off. What model is the board?
Reply 30273 of 31464, by Ydee
It may have been a coincidence, but with a similar passive cooler (Thermaltake) my memory went out on GF4 Ti 4200 (TSOP), so adding fans to support airflow is just as well.
Reply 30274 of 31464, by vutt
Cleaned and Improved my NV6600GT cooling solution. Put Raspberry Pi surplus heatsinks into good use.
Arctic Accelero S2 is capable cooling it just fine. Interesting observation about memory chips - only top 2 got hot, bottom right ones stayed cool. Also while memory chips in use are hot they are not the hottest elements - power delivery section is even hotter. Most of the actively cooled GT6600-s have horizontally aligned heatsink fins, so active cooling is probably recommended for this card.
Reply 30275 of 31464, by tehsiggi
roxfly wrote on 2025-10-11, 06:29:
The 9700Pro does not only use 12V.
In fact, most of the power consumed is on 3.3V and 5V - I've measured it:
https://tehsiggi.github.io/agp-power-monitor/ … deon9700pro_128
It's a not an uncommon thing on 9700s that if the power is insufficient, you'll get artifacting. There have been threads about this here as well.
The R300 used in the 9700 has a thermal diode, but it is not used in any regular design. It would require an LM63 on the board to be populated, which iirc. has never been done. Therefore there is no way that a overheat on the 9700 would cause a shutdown.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 30276 of 31464, by dominusprog
sunkindly wrote on 2025-10-10, 21:00:
Cyrix used QUAKE! Cyrix hurt itself in confusion... […]
Cyrix used QUAKE!
Socket 2 have one extra contact, so why not 😏.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 30277 of 31464, by ubiq
tehsiggi wrote on 2025-10-11, 10:33:
The 9700Pro does not only use 12V. In fact, most of the power consumed is on 3.3V and 5V - I've measured it: […]
Thanks, good to know! Part of the reason I post here is because I don't necessarily know what I'm doing and appreciate the advice and wisdom of those here who do. 😌
I never was getting any artifacting whatsoever with the card, which I considered pretty encouraging with regards to the health of the card.
During my troubleshooting, I took the heat sink off to visually inspect it and redo the thermal paste, which I hadn't done since getting it so who knows how old it was:
The attachment IMG_3105.jpeg is no longer available
The attachment IMG_3104.jpeg is no longer available
Nothing looked leaky, so I buttoned it back up (being a bit generous with the paste due to that pretty proud shim its got)
I ultimately ruled out the 9700 Pro as the issue and considered the PSU itself to be the problem. I also ruled out CPU thermals as well as the mainboard caps (I recapped the mobo when I got it - yes, it needed it). The powering off issue required physically toggling the physical power switch on the PSU to get it started again. It's a brand new PSU, but of course that doesn't mean it's good. For now, putting the 9700 on its own rail instead of the one driving the HDs seems to have fixed things.
In terms of 9700 Pro care - should I put heat sinks on the ram? If it came to it, I'm probably up to replacing the caps on the card, but the ram would be another story.
Reply 30278 of 31464, by PcBytes
IMO would very much recommend. My 3d Prophet largely survived thanks to RAMsinks.
Reply 30279 of 31464, by EduBat
Fired up the old Commodore 64 and fixed the datassette with a new belt.
