Reply 30440 of 31554, by Ozzuneoj
- l33t
After messing with this quite a bit I figured it'd be worth posting. I picked up a Dell OEM branded ELSA Gloria XL PCI graphics card a while back and decided to give it a test run today.
(Old seller pics from when I bought it.)
This was kind of a ridiculous card in 1997. It is equipped with a 3D Labs GLiNT MX + GLiNT Delta chipset for 2D + 3D accelerated graphics in Windows, and an S3 Trio64V2/DX strictly for DOS. The 32 chips that cover most of the front and back make up the 16MB frame buffer. The three chips by the expansion RAM slot make up the 24MB Local Buffer for... whatever kind of CAD or modeling activities this monster is intended for. With a 16MB expansion, it will then have 40MB local buffer and 16MB frame buffer, for a total of 56MB, plus 1MB for the Trio64V2/DX. I don't have any systems running NT or 2K, so I figured I'd give it a try in 98SE if I could find drivers.
This proved to be a bit harder than I'd expected! There aren't any 9x drivers for this card on the VOGONS driver library. However, I did find some listed here:
https://ftp.zx.net.nz/pub/archive/ftp.compaq. … 12000/11501.txt
(Search for Gloria-XL; there is also one listed for Gloria-L)
I was able to find an archive of this Compaq FTP here:
https://ftp.zx.net.nz/pub/archive/ftp.compaq. … /sp11501-12000/
When I installed the XL Win95 drivers (which the doc says are from October 1999, but the installed driver was from 1998?), it didn't really do much. I had to keep messing with device manager and telling it to find things in windows folders (I love how C:\Windows\INF is invisible to device manager in 98SE... nice) for it to finally identify the GLiNT XL itself. Eventually it did "work", but changing resolutions to anything beyond 800x600 at 256 color caused severe screen distortion.
I then found a driver for the similar Gloria-XXL on this page:
https://elsa.retropc.se/gloria/xxl/index.htm
They are listed under:
Drivers for Windows 95 and Windows 98
ELSA GLoria-XXL, Windows 9x driver and tools
gxxl_w9x.zip (914 KB) 25 Jan 1999 v4.10.01.0203-0012
I had to do some similar struggling with Device Manager to get them to install (there is also no setup program with this set), but I'm happy to say that this driver allowed higher resolutions in 98SE without the issues the other driver had. I'm not sure what is causing it (could be unrelated to this card or drivers) but I do get an odd mouse cursor vibration effect at higher resolutions. Still, it allowed me to set 1600x1200x24bit @ 85Hz on my CRT.
Also, I only did a tiny bit of game testing because I know this card is really intended for OpenGL under NT, and in the random game I tested (old demo of Jedi Knight 2) I did get actual 3D acceleration (success!), but it was not very fast and there were some graphical anomalies. The most obvious was an odd kind of green-tinted stripe pattern on textures.
I also experienced one BSOD. It could be the card, but it is more likely to be the very sketchy drivers. I will have to install NT some time to test out all of these pro graphics cards from the 90s with better drivers. 😀
Anyway, I have attached all of the drivers mentioned to this post and named them in a way that is hopefully helpful.
