Reply 30700 of 30795, by GigAHerZ
- Oldbie
GigAHerZ wrote on 2026-01-11, 15:06:Found these products with the help of AI - i asked for ingredients, searched what is locally available, and then described the i […]
GigAHerZ wrote on 2026-01-10, 15:02:...
I now need to go to find some things to weld back all other plastic clips that have broken off - the back case has nothing to hold on to. Thankfully i have all the broken pieces. Found some local products with the help of AI to actually weld and recreate ABS plastic. I hope i don't have to just glue the backside onto the monitor somehow...
...Found these products with the help of AI - i asked for ingredients, searched what is locally available, and then described the ingredients of the products to the AI to confirm if these are the right tools for the job.
Just applied these products on some plastic pieces.
The yellow product is like water, but it makes the Compaq's plastic a bit smeary-pastey on the surface it was applied after 10-15 seconds. (I used cotton swab) Applied it to the both sides of the break.
Then i took the red bottle. This is thicker, like some rubber-glue. Applied a thin coat on one piece on the broken surface.
Then pushed the pieces together and as AI predicted, I could even see some plastic slightly bulging out as it was soft. (I hope I still am in the margin of error for the measurements 😀 )
Now i have to wait at least 24h before I could apply a second coat of the red one to build a bit more material on the pieces.
But so far it's promising - I've never had myself any chemistry that could "melt" the original plastics. I hope it works.It would be amazing, if at last, i have some sort of procedure and approach to repairing plastics once and for all. I already have 2-part epoxy to create "hard rock, concrete" in places where i have room and don't need any flexibility. (Think of laptop's display hinge screw posts) I really-really hope i have found "the way" now for slightly flexible plastics.
In summary:
Yellow Arrow 901 - Used only initially to soften the original plastics.
Red Arrow 1108 - Used initially as well as later to build additional material. After the first steps, some tiny cracks may appear in plastic - these can also be filled with this 1108 after 24+h.The original usage for those products is to "glue" together PVC piping for hot and cold water.
So... I think it did the trick.
The yellow bottle just softened/melted the plastics so i could position the pieces in their place and only thing that kept them in their place was their own softened plastic itself. The yellow bottle is a solvent of some kind. It doesn't leave anything behind by itself.
Then after every 24 hours, i added a thin covering from the red bottle. This is like some thick syrup and a bit brownish. That is what is most visible on the pictures. I added it both to the broken areas as well as reinforced the areas that hadn't broken yet. I did maybe about 4 coats, 24h for each coat and then waited about 48h until now.
I tried to put the covers back on now, and i think i succeeded. No parts broke of and as much as i can confirm (while the covers are now fully on) these parts stayed solid.
At last, I have some kind of solution to fix broken clips!
Because I've never had a solution for that problem, while the problem has existed for me for over a decade, it feels like magic!
I can now go and put together a full Compaq Deskpro set!
A little about software engineering: https://byteaether.github.io/
