Reply 30940 of 31157, by tehsiggi
- Member
Some more R300 series fun in the lunch break.
So I build the jankiest temperature controlled setup possible to characterize the NTC on R300/R350/R360 GPUs. It consists of a styrofoam box, a 40mm fan, a 20W light bulb, Uni-T thermometer and a cheap module to control the lamps heating.
I used a voltage divider consisting of the GPUs NTC and a 100kOhm 0.1% low-temp-co resistor, powered by a lipo cell (gives nice, clean and stable voltage) to determine the resistance of the NTC.
The results look like this:
I know, it's no-where scientific, but for me it's honestly good enough.
So calculated my results look like this:
Beta Model Parameters
Beta (B): 4329.96 K
R25: 94652.81 Ω
Steinhart–Hart Coefficients
A = 0.0008714636826900755
B = 0.00020751383834629025
C = 0.00000006987140028267289
It's relatively safe to assume it's a beta 4250K part, which is pretty common.
This will now help me to read the temperature on R300 based cards, pretty close to the die. Unfortunately, no diode in the die. But hey, better than nothing.
