Reply 31760 of 31953, by jdredd
rasz_pl wrote on 2026-09-04, 22:42:so much reinventing teh wheel going on :) COMrade https://github.com/yyzkevin/COMrade here in use https://github.com/ahmadexp/Op […]
jdredd wrote on 2026-09-04, 03:55:Mixing AI slop and DOS development. To create a DOS bridge to dev and deploy from my Windows 11 machine using FPC in my case ( or TP7 directly on the dos box ) and/or using Claude Code to work and write code, test, and document.
so much reinventing teh wheel going on 😀 COMrade https://github.com/yyzkevin/COMrade
here in use https://github.com/ahmadexp/Open-Source-PC110 … overy/Live-Dump
and win95 version COMR95.EXE https://github.com/ahmadexp/Open-Source-PC110 … oftware/COMrade
Both used by https://github.com/Mike1978uk/win95-intel-inboard-386pc and https://github.com/ahmadexp/Open-Source-PC110 projects
Nice! I didn't even go looking for existing solutions...
I went the other route with networking since I have a PicoMem, so using the wifi. Plus I use serial port for my mouse and my old 8086 PS2 only has the UART 8250... I do have null modem cable that I used before with this.
But it was so stinking slow.
The PS2 is the only retro system I have to play with.
Next week when it shows up, I hope using an Extron RGB-HDMI 300 A Scaler to live feed Claude streaming VGA signals can help even further when it comes to more graphic mode stuff.
This was mostly a fun project for myself. I wanted to see if I could have it expose a way to do rapid dev... and it did and worked well.. and figured if people want it.. they can.. if not.. oh well. Won't keep me up at night 😀
I will checkout COMrade!
