First post, by NJRoadfan
I just picked up the following from a friend:
-Gigabyte GA-7DX, with a 2004 revision BIOS and AMD 761 north bridge (!)
-Athlon XP 2000+ Palomino core
-1GB DDR RAM
-Some generic GeForce 3 Ti 500 video card
-SB Audigy Platinum with breakout box
-Pioneer slot loading DVD-ROM
-Plextor PlexWriter IDE CD Burner
-Running Windows XP as usual
I really don't have a need for such a system, so its likely going to get gutted. It came in a nice period Antec Performance Plus/Chieftec Dragon DX-01BD black case that I have other uses for and the Audigy already has a home in a newer machine. Seems like it was a high end machine for the time. Looks like the northbridge fan was replaced once, its clear with a blue LED on it now. Got one swollen cap on the board, typical for a machine from the "era of crap hardware" (2002 was the worst year IMHO).
Reply 1 of 15, by obobskivich
Yeah not a bad machine for ~2002 for DX7/8 gaming at all. Either use it for XP for old games, or throw something like Puppy Linux on it and it'll make an okay web browser as long as it doesn't have to do heavy HD video or something.
Reply 2 of 15, by NJRoadfan
Thing is, I have a Socket 478 machine that covers that period well... and has nice things like USB 2.0. I'll throw the board in a box, it'll find a home somewhere.
Kinda hard to believe, but I found the site of the company that built this machine, the configuration is close to the "Awesome 3110"
https://web.archive.org/web/20020812050507/ht … es=45&cpubase=2
ABS computers also seems to be a precursor to... newegg! They share the same mailing address.
Reply 3 of 15, by joacim
I can't think of anything that needs the hardware from that era, so any newish system with winxp should run be able to run early winxp compatible software. It is a cool computer from the period tho. 😀
I've been thinking about resurrecting my old socket a system myself, but I don't really have a reason to since all my current machines can run winxp well enough.
Reply 5 of 15, by NJRoadfan
Heh, one of the many reasons why I despise VIA chip sets. It amazes me the amount of crap they put out over the years and they are still in business. nVidia wasn't much better in the area of Athlon chip sets, but they finally got their act together.
Reply 6 of 15, by RacoonRider
What's wrong with nforce?
Reply 7 of 15, by swaaye
Rank Moderator
Moderator
The only problems I can think off offhand were the NV SW IDE/SATA driver being trouble with some optical drivers and the unstable firewall software they advertised for nForce 3/4. Best to use the OS IDE driver, and to avoid that firewall.
Reply 8 of 15, by NJRoadfan
Yes, the firewall and IDE drivers are what I'm referring to with the nForce. Even the nForce 2 IDE/RAID was a chore to get working on Vista/7, you had to use the XP drivers to get it working, period, as the built in IDE drivers wouldn't detect any drives in setup. That and nVidia got rid of SoundStorm, which was a decent on board DAC solution.
EPIC RANT FOLLOWS
While the Athlon was clearly whipping Netburst left and right in terms of performance, the horrible chipsets kept me well away from it. Its one of the reasons I stuck with my 440BX P3 machine for so long. This machine is actually the first AMD acquisition from this era of hardware (I had a Socket 423 Dell Dim8100 that went to uxwbill which oddly enough I also got from the same friend this Athlon came from).
I had to support these machines when they were new (I was a PC repair tech from mid-1998 to mid-2005). They were nothing but headaches. There would be what we techs called "transient running issues". Basically odd random behavior and crashing that we couldn't reliably reproduce or isolate with hardware swapping. Think of the problems caused by bad RAM, but the RAM tested out fine and known good RAM was swapped in as well! The above Athlon system even played tricks on me last night. It started BSODing on boot. I was going to blame nVidia's fine video drivers (I have stories about nVidia and their XP drivers too), but it then eventually stopped booting with the long-short-short beep code. It just randomly stopped detecting the video card! Re-seating the video card didn't fix the problem, but kicking the machine in a mild rage persuaded it to work again. EDIT, RacoonRider might understand what I'm talking about right now.
While the Netburst P4 machines would cook eggs idling on a Windows desktop and lacked "teh snappy", they were usually stable (outside of the boards that had cap failures, of which there were many). Pretty much everyone used Intel chip sets in their P4 machines, which helped. Any time I see VIA, I have flashbacks of 4-in-1 driver hell. If only the customers knew what we had to do to get their beloved computer to consistently work right!
Reply 9 of 15, by RacoonRider
You got me 😁 When I started that build I actually wanted to go Netburst, but these machines are everywhere. They keep cooking eggs while idle and they are simply boring, with long pipelines and high megahertz that mean nothing. That's why I love C2D with deep dark passion - they lack everything I hate about Netburst.
That nforce2 board is not as bad as one would think after reading your post. I keep away from RAID and use Audigy for sound (I don't know if I have to, just heard bad things about both); the stability problem might be gone for now. Beleive it or not, I'm fairly happy with this system. I hardly had to tinker with it at all, it's just find the parts - connect them together - voila! 😀
Reply 10 of 15, by Nahkri
I had socket A platforms from 2000-2007 and had no chipset problems.
First i had a Soltek mb with via kt133 on windows98se,then an Epox with nforce2 windows 98se ,then Abit with nforce 2 ultra 400 and at work i used another Epox with nforce2 with igp both with windows xp and had absolutly no problems.
Mb:JetWay 542C Ali Aladdin 5
Pr:Amd K6-3+:400MHZ @ 550 mhz
Ram:256mb
3D:Voodoo 3 3000 16MB
Sound:Turtle Beach-Montego A3dExtreme(Aureal Vortex 1)
Hdd:Maxtor Fireball Plus 8 40g,7200rpm,2mb cache
Os:Windows 98SE
Reply 11 of 15, by obobskivich
Pretty much same here, and saw many similar configurations over the years too. Socket A isn't really so bad, but it doesn't have the same level of polish that you can expect from 875p with S478 or similar. 😊
On Soundstorm - it's more than just a DAC (or codec). It's got h/w processing too (https://en.wikipedia.org/wiki/SoundStorm). 😀 Shame that they dropped it off after nForce 2 though... 😢
Reply 12 of 15, by joacim
The chipset on my Abit NF7-S v2.0 (nForce 2 Ultra 400) was good enough for me (stable, decent onboard audio), but the board itself caused some problems for me. The board could randomly shut down my computer and start blaring a siren-like sound through the PC speaker. It would do this every time I booted my computer until I reseated the CPU.
I read somewhere that the CPU temperature diode could be the cause, and that the way to fix it was to bend it up a little so it could make contact with the CPU. I never tried the fix because I had already upgraded to a C2D system when I found out about it.
Reply 13 of 15, by Nahkri
My last socket A board was a Abit NF7-S v2.0,ran a Barton 2500+ overclocked to 3200+ and had no stability problems with it,the only problem i had was the nb fan got very noisy,i lubrified it a couple of times but the problem kept coming back,in the end i replaced it with a zalman passive cooler.
Ram:256mb
Os:Windows 98SE
