First post, by Skyscraper
A few days ago I found a Pentium 2 system in an electronic waste dumpster.
The box looks like... I do not even know what to say so here is an image.
I opened the system up and found something that looked like an Asus BX motherboard without an AGP slot. The drives and memory was already gone but a P2 400 was still mounted on the board.
The above picture was not actally how the system looked when I opened the system up. That image was taken after I cleaned the inside of the box. Here is picture of the PSU to get an idea how dirty everything was.
Why diddnt I clean the PSU when I cleaned the rest of the system? Here is why, this is one of the weakest full size ATX PSUs I have ever seen. This system needs something better!
Here is something better.
I found a suitable sound card.
I did also find 2x256 MB SDRAM, a 10GB IBM HDD, a floppy drive and a CD-ROM drive.
Its time to see it the system works! WTF?! is this? I had not even noticed that this is a HP system.
A totally locked Phoenix HP bios. Yey... At least the clock has the correct time.
Here is an image of the system running.
After the HP setback I installed Windows 98 and did a quick 3dmark99 run, the ATI Rage Pro turbo plus is a very fast video card...
Now it was time to settle the HP question once and for all. Its not that I dislike HP as much as it took the system 5 minuts to check the memory every restart without an option to skip. The system halted every restart because the "system fan" was missing and it uses some special fan header... I did not have such a fan and there was no option to turn off this "feature". I went to Asus site and found a similar board, The Asus branded version seemed to be revision 2xx and HPs board is revision 1xx. Close enough for me to chance a crossflash and sure enough it was successful. The board lost a little bit of performance but I can live with that if I do not have to wait for the memory to count SLOWLY from 1 to 512MB everytime I boot the system up.
I ran a few more benchmarks. The system is not exactly fast when it comes to Super Pi.
The Sisoft Sandra scores looks OK.
The CPUmark99 score is pretty low.
All in all as it is, this system gets crushed by my K6-3+@600 when it comes CPU performance.
I will add a PCI video card, perhaps my Voodoo 3 2000 or my PCI Radeon card.
The crossflash also brought support for at least up to P3 Katmai 600MHz, the Internet do not think Coppermines will work but we will see about that.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 1 of 16, by JayCeeBee64
Rank Retired
Retired
Nice find Skyscraper (and a great job on the cleanup \^^/). My youngest sister still has her old PC, an HP P3 700MHz that her kids now use for school homework and old educational CD-ROM games. I don't remember exactly what motherboard it has (I think it's an Intel 810), but it has the same Rage Pro Turbo video, a 20GB Maxtor hard drive, 512MB of PC100 ram, Phoenix BIOS, and Windows XP Home. It doesn't have the "melty" case though 😀
If you can get a P3 600 or even a 700MHz CPU to work then it will be a good fit with the Voodoo 3 2000; the Radeon 7000 is also good. You could also try a GF256 or GF2 PCI if you have them. The crossflash was a daring move (I don't think I would have tried something like that), but it worked and gave you more flexibility with the BIOS options. The AWE32 is a great addition as well.
A neat job on your dumpster find so far. Keep it up! 😎
Ooohh, the pain......
Reply 3 of 16, by Skyscraper
JayCeeBee64 wrote:
My youngest sister still has her old PC, an HP P3 700MHz that her kids now use for school homework and old educational CD-ROM games...
... If you can get a P3 600 or even a 700MHz CPU to work then it will be a good... ...The crossflash was a daring move (I don't think I would have tried something like that), but it worked and gave you more flexibility with the BIOS options.
Thanks!
Its good to hear that some "normal" people still find use for slow machines like a P3 700 😀
I have tested the P3 600 and it works good. The Katmai brought the performace more in line with the K6-3+ @ 5*120MHz and Im sure it will be even faster in games.
The crossflash lets me slow the system down a bit. Here is a P2 300 @ 100 MHz without L2 running Super PI 1M.
125 MHz with L2, Super Pi 1M
Here is the Katmai 600 running Super Pi 1M
P3 Katmai 600MHz CPU mark 99
Katmai 600 MHz Sisoft Sandra 99
Katmai 600 MHz ATI Rage Pro Turbo 3dmark99
Katmai 600 MHz ATI Rage Pro Turbo runng GL Quake 512*384, 35.6 FPS 😀
Katmai 600 MHz ATI Rage Pro Turbo runng GL Quake 640*480, 23.7 FPS
Reply 5 of 16, by Skyscraper
Robin4 wrote:
Thanks.
Asus still hosts both the manual, bios and drivers for the board.
Reply 6 of 16, by Sutekh94
Nice find! Probably wouldn't be a bad Voodoo2 SLI/Voodoo3 system. Also, is it just me or does the case look like it's been painted at some point?
My YouTube | My DeviantArt
Reply 7 of 16, by Skyscraper
Yes that is very likely, otherwise I want to speak with the people at HPs design department.
On "the Internet" I have read that this board can not run Coppermines because its supposedly one of few Asus BX boards that lack VRM8.4 support.
VRM8.3 should be able to provide 1.8V which too me is close enough but according to the source below this does not work with this exact board either for reasons not given.
http://www.maxperience.com/en/asus-motherboar … asus-p2b-p3-600
I am not satisfied with reading some unverified information on the Internet saying it wont work, I have to try it my self.
For a "non working" CPU the Coppermine Celeron 1100 runs Super Pi pretty fast.
The Sandra 99 scores looks good.
The CPUmark 99 score is also good, the Celeron beats the K6-3+ @ 5*120 (The K6-3+ got 59 as the best score)
The 3dmark99 CPU score is a bit higher with the Celeron.
Time to play some Turok Dinosaur Hunter using the mighty ATi Rage Pro before I add a PCI video card.
Reply 8 of 16, by obobskivich
Nice save there. On the fan failure thing - I have an Asus/HP board with a similar feature - it doesn't need anything special, just a 3-wire connector to whichever sensor it's tied to (usually chassis/system fan) so that it can read tach from it. It will very likely adjust the RPMs to keep the machine relatively quiet too.
It looks like this is probably what the case was like before painting:
http://pcman.sinzy.net/upload/2004/12/HP-1.jpg
The "melty-ness" is runs in the paint; it was painted poorly with a spray-can. If it bothers you, sand it down, prime it, and re-paint it with whatever color you like. 😀 The front cover you'll need paint that can bond to plastics, but you shouldn't have to sand it.
Reply 9 of 16, by Skyscraper
obobskivich wrote:
Nice save there. On the fan failure thing - I have an Asus/HP board with a similar feature - it doesn't need anything special, j […]
Thanks 😀. The board has one 3 pin fan header and one odd 4 pin header, It would not be hard to figure out what pin goes where on the 4 pin header but its now a non issue 😀
The new look dosnt bother me much, it masks the HP look 😜
It is time to turn up the heat!
I managed to get the Radeon 7000 PCI (some OEM card) going.
There is no option to disable the Rage Pro in the BIOS setup so lets just say there were some catch 22 moments and Kafka feelings involved.
3dmark 99. Not good not bad.
3dmark 2000. A little bit slow.
GL-Quake 640*480 32bit. 86.2 FPS
GL-Quake 1024*768 32bit. 41.5 FPS. A few more FPS would not hurt.
Lets see if we can speed things up.
I found the problem, it shows green.
If speed has a colour, it must be red!
Did the overclocking yield any benefits?
3dmark 99. Not a huge gain.
3dmark 2000. Here we see a larger gain.
GL-Quake 640*480 32bit. 98.8 FPS.
GL-Quake 1024*768 32bit. 51.9 FPS. Much better.
Reply 10 of 16, by obobskivich
Very nice with the 7000! I wonder if a PCI 92xx would do much better? (iirc all of them are R200 based, similar-ish to the 8500LE).
And no idea on the 4-pin; I thought PWM didn't come into being for years after Pentium 3-era (modern PWM fans use 4-pin headers; I don't know if that's what you have there or not though). On the Asus/HP I have it has 3 fan headers: CPU, CHS, and PSFan - PSFan doesn't appear to do anything (you can connect it, not connect it, etc it doesn't matter), the other two will halt the machine if they aren't hooked up to a fan, and the board does control speed on both of them. But they're all 3-pin like most any other motherboard, and will hook up to fairly standard fans (I say fairly because the board tends not to like 120mm fans that want to run at <1000 RPM).
Reply 11 of 16, by JayCeeBee64
Rank Retired
Retired
Great results so far Skyscraper! Looks like the Asus board is much more capable than what I anticipated. And overclocking the Radeon 7000 that far yields nice speed gains as well 😁 . Now I really wonder what the Voodoo 3 can do.
I suspected as much. Looks like someone tried some sort of "artistic expression" with the HP case, but only made it half-way through the process 😜
Reply 12 of 16, by Skyscraper
Im sure the Radeon 92xx would be faster, they are rare around here though.
The Voodoo will crush the Radeon 7000 in games that support Glide and probably even be faster in some games when running Open GL but I doubt its faster in Direct 3D and it wont do 32 bit colour.
I will probably try out the Voodoo 3 in this system but I have a feeling the Radeon is the card that will end up in this box.
Reply 13 of 16, by Skyscraper
The Voodoo 2000 PCI is in my "Unreal build" that I used for playing Unreal last year 😀
That box happens to be a Celeron 1100 and this box is a Celeron 1100...
I think I am too lazy to move the Voodoo 3 to this build but I need to check the PSU in the other box for bad caps and perhaps upgrade that system a bit.
I might aswell bench a little while Im at it.
The end result of this build is a very fast Windows 98 system that runs all Windows games from 1997 to 2000 but would struggle with many games from 2001 and 2002.
Here is a really bad video of a restart to get an idea how snappy the system is, the HDD is an old 10GB IBM IDE drive with a distinct sound...
http://www.filedropper.com/cimg0325
Reply 14 of 16, by chinny22
Nice save! With a case looking like that I'm not sure I would have bothered...yeh OK open any computer I come across.
At first I was thinking killer dos PC with a P2, isa but no AGP but looks like you have a real nice voodoo PC. or at the very least having fun with PCI video cards
Reply 15 of 16, by shamino
The coppermine support is probably the same situation as with many of the older revision P2B and P3B boards. Up until a certain point, Asus didn't guarantee what VRM the board would have installed. Yours apparently has a coppermine capable voltage regulator.
If it were an older VRM, it wouldn't recognize the VID code that the processor requests. In principle, this could cause a completely incorrect voltage to be supplied, destroying the CPU (it wouldn't just be 1.8v). In actual practice, many(most?) of the incompatible VRM chips will refuse to provide power if they don't recognize the VID, so nothing destructive would happen. At least that's been my experience so far, and I've seen that behavior documented in some datasheets.
However, in case anybody is getting ideas from this - when dealing with an unknown, the safest approach would be to research the VRM chip rather than trusting that a failsafe has been implemented. It might not be. You can also test with an empty slocket, using jumpers to select a Coppermine voltage, and use a multimeter to measure what voltage it's actually providing.
Reply 16 of 16, by Skyscraper
This is why I jumpered the slotket for 1.8V which is the lowest voltage the VRM 8.4 normally supports.
(VRM 8.5 supports the whole Coppermine voltage range)
Doing the research before tinkering with beloved systems is very good advice.
