Reply 2100 of 3174, by shock__
- Oldbie
Updated BOM (formating is correct in the .txt ... the code tag doesn't do it proper justice)
Also ... 2 generations of prototypes + current RC: https://i.imgur.com/8BXtlUC.jpg
ARGUS Release Candidate Bill of materialsCapacitors ceramic:Part Value Package NoteC0 100nF SMD 0805C1 100nF SMD 0805C2 100nF SMD 0805C3 100nF SMD 0805C4 100nF SMD 0805C5 100nF SMD 0805C6 100nF SMD 0805C7 100nF SMD 0805C8 100nF SMD 0805C9 100nF SMD 0805C10 100nF SMD 0805C11 100nF SMD 0805C12 100nF SMD 0805C13 100nF SMD 0805C14 100nF SMD 0805C15A 22pF SMD 0805C15B 22pF SMD 0805C16 100nF SMD 0805C16A 22pF SMD 0805C16B 22pF SMD 0805C17 100nF SMD 0805C18 100nF SMD 0805C20 100nF SMD 0805C22 100nF SMD 0805C30 100nF SMD 0805C31 100nF SMD 0805C32 100nF SMD 0805C33 100nF SMD 0805C40 100nF SMD 0805C41 100nF SMD 0805C42 100nF SMD 0805C60 100nF SMD 0805C61 22pF SMD 0805C62 22pF SMD 0805C63 470pF SMD 0805C64 470pF SMD 0805C71 470pF SMD 0805C73 470pF SMD 0805C80A 6.8nF SMD 0805C80B 6.8nF SMD 0805C81A 6.8nF SMD 0805C81B 6.8nF SMD 0805C82A 6.8nF SMD 0805C82B 6.8nF SMD 0805C83A 6.8nF SMD 0805C83B 6.8nF SMD 0805C84 1nF SMD 0805C85 1nF SMD 0805C86 100nF SMD 0805C93 100nF SMD 0805C706 2.2uF SMD 0805C707 2.2uF SMD 0805C708 2.2uF SMD 0805C709 2.2uF SMD 0805C710 2.2uF SMD 0805C711 2.2uF SMD 0805
C712 2.2uF SMD 0805C713 2.2uF SMD 0805C714 2.2uF SMD 0805C715 2.2uF SMD 0805C716 100nF SMD 0805CA1 100nF SMD 0805CA2 100nF SMD 0805* Ratings shouldn't be lower than 35VCapacitors electrolytic:Part Value Package NoteC200 10uF, 35V* Through Hole 2.5mm Pin distance, 6mm diameter**C703 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C704 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C717 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C718 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C719 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C720 10uF, 35V* Through Hole 2.5mm Pin distance, 6mm diameter**C721 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C722 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C723 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C724 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**C725 10uF, 35V* Through Hole 2.5mm Pin distance, 6mm diameter*** Voltage ratings are minimums, personally I used 50V capacitors for all.** A reasonable maximum height is 8mm when intending to use a daughterboard, otherwise virtually any height goesConnectors:Part Value Package NoteSIMM 72 Pin SIMM connector, 90°, 45° or 0° i.e. AMP 73824862 (tested)J1 3.5mm Audio Jack Stereo raised i.e. CUI SJ1-3543NJ2 3.5mm Audio Jack Stereo raised i.e. CUI SJ1-3543NJ3 3.5mm Audio Jack Stereo raised i.e. CUI SJ1-3543NP8 15 Pin female SUB-D PrintMPC 1X04, 90° Pinheader 2.54mmP45 1X04, 90° Pinheader 2.54mmResistors:Part Value Package NoteR1 10K SMD 0805R2 10K SMD 0805R3 10K SMD 0805R4 10K SMD 0805R6 10K SMD 0805R7 10K SMD 0805R8 10K SMD 0805R9 10K SMD 0805R10 61.9K SMD 0805R11 10K SMD 0805R12 10K SMD 0805R13A 10K / nc SMD 0805 Refer to silkscreen or note for U31R13B 10K SMD 0805R13C 0 / nc SMD 0805 Refer to silkscreen or note for U31R14 10K SMD 0805R15 10K SMD 0805R16 10K SMD 0805R17 0 SMD 0805R18 0 SMD 0805R40 200 SMD 0805R41 nc SMD 0805 not populatedR52 5.1K SMD 0805R53 5.1K SMD 0805R54 5.1K SMD 0805R55 5.1K SMD 0805R60 5.1K SMD 0805R61 22K SMD 0805R62 390 SMD 0805R63 10K SMD 0805R64 5.1K SMD 0805R65 22K SMD 0805R66 390 SMD 0805R67 10K SMD 0805R70 10K SMD 0805R71 20K SMD 0805R72 10K SMD 0805R73 20K SMD 0805R74 75 SMD 0805R75 20K SMD 0805R76 75 SMD 0805R77 20K SMD 0805R80 2.2K SMD 0805R81 2.2K SMD 0805R82 2.2K SMD 0805R83 2.2K SMD 0805R84 200 SMD 0805R85 200 SMD 0805R600 5.1K SMD 0805R602 5.1K SMD 0805R605 5.1K SMD 0805R606 5.1K SMD 0805R607 5.1K SMD 0805R608 5.1K SMD 0805R609 10K SMD 0805R610 5.1K SMD 0805R611 5.1K SMD 0805R612 0 SMD 0805R614 0 SMD 0805R615 0 SMD 0805R616 nc SMD 0805 not populatedR617 nc SMD 0805 not populatedR618 nc SMD 0805 not populatedR619 nc SMD 0805 not populatedR620 nc / 0 SMD 0805 See schematic. Default: not populated* all resistors 1/8W (except R620)Integrated circuits:Part Value Package NoteU0 DRAM 256K*16 or 1024K*16 (70ns or less) SO40 / SO42 i.e. HY514260BJC-60 (optional Socket: i.e. AMP 3-822265-2) or HY5118160JC-70U1 DRAM 256K*16 or 1024K*16 (70ns or less) SO40 / SO42 i.e. HY514260BJC-60 (optional Socket: i.e. AMP 3-822265-2) or HY5118160JC-70U10 AM78C201AKC QFP160U30 AT93C66SC SO8U31 IW78C21M1 / 29F800 (70ns or less) SO44 Socket optionally supported (i.e. Yamaichi IC179Z-44)*U32 74F373DW SO20U33 74F373DW SO20U40 74F32D SO14U60 TL082C SO8U70 MS6308 SO8* alternatively one can solder 2x 2x25 1.27mm SMD female headers (i.e. 20021321-00050T4LF) onto the elongated pads (spanning U31 and U31EX), for a future daughterboardset R13A and R13C accordingly (IW78C21M1 -> R13A = nc, R13C = 0)(29F800 -> R13A = 10k, R13C = nc)Voltage regulators:Part Value Package NoteU20 7805 (1A or 3A) TO-220U22 7905 (1A) TO-220Oscillators:Part Value Package NoteX17 24.576MHz HC49/SX18 16.9344MHz HC49/SConnectors optional:Part Value Package NoteX1 2X31 Pinheader 2.54mmX2 2X18 Pinheader 2.54mmCON 1X02 Pinheader 2.54mmIW 1X02 Pinheader 2.54mmJP8 1X02 Pinheader 2.54mm
Current Project: new GUS PnP compatible soundcard
[Z?]
